2021 Workmaster 55 3 Point Stuck Up
/ 2021 Workmaster 55 3 Point Stuck Up #1
mytungsten
New Holland Workmaster 55
When trying to use the 3 point today, it stays stuck in the up position. Made sure that the Lift-O-Matic was turned off but the levers are not changing anything. We can see that the levers are rotating on the back of the tractor, but they have no affect. We tried to put weight on the 3 point and then lower it, but to no avail. I am looking for other things to try before calling the dealer to have someone come out and look.
/ 2021 Workmaster 55 3 Point Stuck Up #2
Drop rate knob under the seat?
Unfortunately it doesn’t have one, I looked all over for one
/ 2021 Workmaster 55 3 Point Stuck Up #5
I would put weight on it and cycle the Lift-O-Matic system several times quickly with both levers all the way forward in float.. It may have a piece of trash in the system blocking it from lowering. The service manual does not offer much help.
/ 2021 Workmaster 55 3 Point Stuck Up #6
Also I would run the rpms up to 2000 on my WM75. That is PTO speed for it.
/ 2021 Workmaster 55 3 Point Stuck Up #7
Were you able to fix the problem?
