Grading 2019 Front Blade Hydraulics
/ 2019 Front Blade Hydraulics #1
Anonymous Poster
Epic Contributor
Just installed the 2019 60" front blade on my 2410. When I turn the blade to the right, and go into fast "dump". or 2nd detent, the blade shoots to the left!!! Its a real pain when finish plowing. Anyone else seen or have this problem.
Rob
/ 2019 Front Blade Hydraulics #2
Rob
I see you put a 2019 blade on a 2410. Did you use a loader valve? I was wondering if you use a lower arm on the 3PH to raise the blade, which means you would probably have no down pressure. Do you have a part# for the lift kit.
Thanks Bud
The 2019 is a front blade which works off of the "loader" hydraulics only, so the 3pt is not involved in the operation of the blade.
/ 2019 Front Blade Hydraulics #4
Rob
The reason I asked about the blade is because I have the whole setup for a B7100. I want to use the blade, but not the part (lift kit) that connects it to the tractor. That's why I was wondering if you had the regular frame for the blade, or if you attached it to the loader frame. If you have the lift kit I would apppreciate if you could give me the part number.
Bud
2016 Ford Transit 350 Cargo Van (A61573)
2016 Ford Transit...
2011 Ford F-250 Pickup Truck (A61573)
2011 Ford F-250...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
