Grading 2019 Front Blade Hydraulics
/ 2019 Front Blade Hydraulics #1
Anonymous Poster
Epic Contributor
Just installed the 2019 60" front blade on my 2410. When I turn the blade to the right, and go into fast "dump". or 2nd detent, the blade shoots to the left!!! Its a real pain when finish plowing. Anyone else seen or have this problem.
Rob
/ 2019 Front Blade Hydraulics #2
Rob
I see you put a 2019 blade on a 2410. Did you use a loader valve? I was wondering if you use a lower arm on the 3PH to raise the blade, which means you would probably have no down pressure. Do you have a part# for the lift kit.
Thanks Bud
The 2019 is a front blade which works off of the "loader" hydraulics only, so the 3pt is not involved in the operation of the blade.
/ 2019 Front Blade Hydraulics #4
Rob
The reason I asked about the blade is because I have the whole setup for a B7100. I want to use the blade, but not the part (lift kit) that connects it to the tractor. That's why I was wondering if you had the regular frame for the blade, or if you attached it to the loader frame. If you have the lift kit I would apppreciate if you could give me the part number.
Bud
(2) CATTLE SHUTE RAILS (A64280)
(2) CATTLE SHUTE...
(1) UNUSED 9.5-16 TIE W/ 6 LUG RIM (A64280)
(1) UNUSED 9.5-16...
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
Kubota Snow plow with subframe
Kubota Snow plow...
(2) Lights (A64119)
(2) Lights (A64119)
Landhonor Hydraulic Logging Winch (A66285)
Landhonor...
