Grading 2019 Front Blade Hydraulics
/ 2019 Front Blade Hydraulics #1
Anonymous Poster
Epic Contributor
Just installed the 2019 60" front blade on my 2410. When I turn the blade to the right, and go into fast "dump". or 2nd detent, the blade shoots to the left!!! Its a real pain when finish plowing. Anyone else seen or have this problem.
Rob
/ 2019 Front Blade Hydraulics #2
Rob
I see you put a 2019 blade on a 2410. Did you use a loader valve? I was wondering if you use a lower arm on the 3PH to raise the blade, which means you would probably have no down pressure. Do you have a part# for the lift kit.
Thanks Bud
The 2019 is a front blade which works off of the "loader" hydraulics only, so the 3pt is not involved in the operation of the blade.
/ 2019 Front Blade Hydraulics #4
Rob
The reason I asked about the blade is because I have the whole setup for a B7100. I want to use the blade, but not the part (lift kit) that connects it to the tractor. That's why I was wondering if you had the regular frame for the blade, or if you attached it to the loader frame. If you have the lift kit I would apppreciate if you could give me the part number.
Bud
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
20ft 2-Door Shipping Container (A61572)
20ft 2-Door...
UNUSED SDLANCH STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
2011 Freightliner B2 School Bus (A61573)
2011 Freightliner...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
