2015 Case 55C loader leak rate
   / 2015 Case 55C loader leak rate #1
jk96
Veteran Member
Missouri
Kubota L6060
Just wondering if anyone knows what the factory specs are for bucket leak rate on this tractor? It is a 2015 Case 55C with CVT trans. The bucket tilt leaks down both during use and when sitting. The leak rate to me is unacceptable. With a load on the tractor, the rods are moving out of the cylinder at a rate just greater than 1" per minute. With forks and a pallet you can watch it drop. I currently have the tractor back to the dealer for that issue and a few others. They are trying to tell me that it is within factory spec and want to try to fix with a check valve. I am having a hard time believing that the current leak rate is within factory spec. If using forks you have to unload a pallet of items within 4-5 minutes otherwise you have to readjust the loader to keep from dumping the load.
Jeremy
   / 2015 Case 55C loader leak rate #2
Jeremy
Jeremy, what was the problem? lt190b
   / 2015 Case 55C loader leak rate #3
My 55C loader does not drop at all with no load. It will drop about an inch per hour with a load in the bucket or on the forks. With a load on the forks the tilt rate is Quite substantial.
LandHonor QA PTO (A44502)
LandHonor QA PTO...
BOBCAT S175 (A45333)
LULL 644B-42 (A45046)
TMG-WC42 3 Point Chipper Skid Steer Attachment (A42745)
TMG-WC42 3 Point...
2014 International DuraStar 4300 Bucket Truck, VIN # 3HAMMAAN0EL767732 (A44391)
2014 International...
1979 Trail 40 ft Hopper Bottom Grain Trailer - Dual Grain Doors and Leaf Spring Suspension (A44789)
1979 Trail 40 ft...
