2015 Case 55C loader leak rate
/ 2015 Case 55C loader leak rate #1
jk96
Elite Member
Missouri
Kubota L6060
Just wondering if anyone knows what the factory specs are for bucket leak rate on this tractor? It is a 2015 Case 55C with CVT trans. The bucket tilt leaks down both during use and when sitting. The leak rate to me is unacceptable. With a load on the tractor, the rods are moving out of the cylinder at a rate just greater than 1" per minute. With forks and a pallet you can watch it drop. I currently have the tractor back to the dealer for that issue and a few others. They are trying to tell me that it is within factory spec and want to try to fix with a check valve. I am having a hard time believing that the current leak rate is within factory spec. If using forks you have to unload a pallet of items within 4-5 minutes otherwise you have to readjust the loader to keep from dumping the load.
Jeremy
/ 2015 Case 55C loader leak rate #2
Jeremy
Jeremy, what was the problem? lt190b
/ 2015 Case 55C loader leak rate #3
My 55C loader does not drop at all with no load. It will drop about an inch per hour with a load in the bucket or on the forks. With a load on the forks the tilt rate is Quite substantial.
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
John Deere 4240 w/ Buhler 695 Front End Loader (A64047)
John Deere 4240 w/...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
