2014 Cat 299 D
/ 2014 Cat 299 D #1
Marek
Here are a few pictures of the machine we have been waiting on.........................
/ 2014 Cat 299 D
Pre cleaner,turbo cover, triple flange idlers.
/ 2014 Cat 299 D
ITS FINALLY HERE. Will put it to work next week and see how it holds up
/ 2014 Cat 299 D #6
That's a good mulching head. Too bad CAT didn't have the new design out. Same motor and rotor but body is completely sealed to keep debris out (including where door cylinder is) and head has lower profile and redesigned skids sit on the ground a little better.
/ 2014 Cat 299 D #7
Where's the rooftop oil cooler? I was told when buying a NEW 299D "2"/299D XHP "2" that it would come as a standard feature along with the forestry debris kit from the factory! I would also make them throw in the standard auxiliary couplers to supply oil flow to your 4 in 1 bucket, grapples, augers, etc... If not, they're about a $2500.00 add on! I had to make adaptors for mine which were nothing but a pain in the but until my local branch negotiated with me for an install. Salesmen and corporate America "HA" Go figure??
/ 2014 Cat 299 D
It would be nice if it were included but its not. Sure it could be added for a price. I think the couplers and hoses on your 415 head are larger than the ones on the 315. Everything here has turned to mud and they are calling for a flash freeze tonight so it will be a while until we get to play with it in the woods.
/ 2014 Cat 299 D #9
I ran my old 315 for a few months before the 415 was delivered. My dealership installed bigger fittings on the hoses coming off the mulcher to accommodate the larger fittings on the loader arms. I think you'll really like that tractor, Over all, I can't complain. CAT has got a pretty neat little rooftop cooler if you ever need to install one and the price isn't too bad either. Good luck to you and keep us posted on how she performs.
/ 2014 Cat 299 D #10
Hi,
How many hours will a tank full of fuel last to you, my 279c only last six hours, a pain in the backside
/ 2014 Cat 299 D #11
It depends on what it's being used for at any given time. I usually average 4 to 5 hours when running the mulching head in normal conditions. When using a bucket or grapple usually you can add a couple of hours to that. However if you are running the machine hard straining it, lugging the engine all day (digging hard clay for instance) it will consume fuel at about the same rate as mulching. There are so many variables like running dull teeth/hammers verses older worn ones that factors into fuel consumption it's really hard to get a solid number out of it. Just my two cents worth.
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
JOHN DEERE 4450 TRACTOR (A63290)
JOHN DEERE 4450...
2018 FREEDOM 28' DBL AXLE ENCLOSED CARGO TRAILER (A63290)
2018 FREEDOM 28'...
2860 (A56857)
2860 (A56857)
86 (A63290)
86 (A63290)
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
