2014 5055e wiring harness repair
/ 2014 5055e wiring harness repair #1
Chase27
2014 John Deere 5055e
I have an opportunity to purchase a low hour 2014 5055e cab tractor. The issue is it has been sitting for over a year and the wiring harness has been chewed by mice and the owner was able to get a guy to get it to start but no other functions. A local Jd store came out and said it was the wiring harness and the repair would be $6500 this was in 2024. I was just looking to see if there is anything else I should look for as it has sat for over a year. Also is that $6500 repair reasonable? Thanks!
/ 2014 5055e wiring harness repair #2
Been there with a 5075E, open station. Instead of a completely new harness, I just splice the chewed wires back together. Used good shrink wrap connections. Didn’t even need a wiring diagram, just payed close attention to wire colors.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
UNUSED RAYTREE RMA42 HYD AUGER (A60432)
UNUSED RAYTREE...
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
78" BOX BLADE (A60430)
