2013 Tundra vs 2013 Ford
   / 2013 Tundra vs 2013 Ford #201
Google "area under the curve" and get back to me.
My F250 has 4:30's. Did yours so we are comparing apples to apples? If it didn't, I could almost understand what you are saying. I have driven some 3:73 F250's with the V10 and it makes a big difference.
Didn't get a chance to Google that yet. Mine has 4.10 gears. I have no pRoblem with the v10, it does just fine. Numbers on paper are what they are ... but, from personal experience, driving both, that 5.7L feels more powerful, and is definitely more efficient overall. To be fair, one positive of the v10 is that it is known to be a generally trouble free and long lasting engine (commercial engine used in commercial trucks and motorhomes).
   / 2013 Tundra vs 2013 Ford #202
You are not comparing vehicles relevant to this thread. Ford doesn't put that engine and transmission in a 2013 F150. The engine changes that took place in 2011 are drastically different.
Have you owned both? I have. The Toyota 5.7 was 381hp/401tq, with a smooth 6spd tranny & 4.30's.
Once you own and tow with both, then you can question my credibility.
Incorrect, the 2013 Tundra uses the same drivetrain as it did in 2010. So when I speak of that vehicle and my experience with it, it is relevant when the thread began with that vehicle as half of the equation.
What did I say that is incorrect? Your list of vehicles you have owned doesn't include a 5.0 liter or ecoboost Ford. You said that you have owned both. Looks like you are trying to compare the V10 F250 to the Toyota 5.7 liter. Am I missing a piece to the puzzle?
   / 2013 Tundra vs 2013 Ford #203
And a decade difference in years
   / 2013 Tundra vs 2013 Ford #204
I'm trying to analyze the characteristics of the Tundra as a tow vehicle (half of this equation), and I'm comparing it to what I have experience with. The point of this thread was to compare a Tundra to a F150 as a tow vehicle. I'm describing my experience of using a Tundra as a tow vehicle. Because my current tow vehicle is an F250, that's what I have available to compare to. If anything, it's even more helpful because, and I don't think anyone would debate this, the F250 with v10 is a much better tow vehicle than an F150, regardless of the engine.
Use common sense, you can figure it out.
   / 2013 Tundra vs 2013 Ford #205
I worked on a 2008 Tundra earlier this week. There were some parts of that truck that were like a 3/4 ton truck and then there were some parts of it that were like a compact truck. It wasn't a bad truck but I thought it felt a little cheaper than a F-150.
   / 2013 Tundra vs 2013 Ford #206
Here is the area under the curve that was mentioned. I know you earlier mentioned some concern for taxing a turbo charged V6 but it has out performed the toyota powertrain in every towing test I have read. Even using common sense, I am not sure how to compare that to the F250. The F250 has about 50 percent higher tow ratings so I would guess it to be superior. I agree the tundra has an awesome powertrain and is probably more reliable but performace and towing capability I would consider it pretty much equal to the F150.
   / 2013 Tundra vs 2013 Ford #207
I've never even seen a towing test between the two. I've been out of the loop since about 2011, just as the EB's were coming out, as I shifted my research and attention to tractors. I have never driven an EB. All I can attest to are the experiences I have had.
   / 2013 Tundra vs 2013 Ford #208
Driving a EB is like driving a early 2000's diesel 3/4 ton. I had a 2007 F150 and our 2011 EB is half again more truck.
Chris
   / 2013 Tundra vs 2013 Ford #209
The torque chart above shows exactly why I choose the 5.7L Hemi, considering I had the Chevy 5.3L dog motor. Look at how far you gotta rev that thing to get any torque out of it. What a pig! :yuck:
The Hemi takes care of me, as I tow moderate loads sporadically. For those towing heavy loads more frequently, I would think the arguement for diesel becomes stronger because the Ford EB fuel consumption should drop quite a bit, seeing as it is still a stoicheometric gasoline engine, right?
I guess I still don't see the case for the EB engine - much more expensive than the naturally aspirated V8s, so would not buy for light/moderate towing. Poorer fuel mileage than diesel for heavy towing, and debatable durability?
:confused3:
   / 2013 Tundra vs 2013 Ford #210
My buddy just traded his 2012 EB in on a new Tundra because the intercooler kept leaking. He likes the truck but not the mileage.
Onsite begins 8:30am / Online begins 9:30am (A50120)
Onsite begins...
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
1988 Comptank Tanker Trailer (TITLE) (A50774)
1988 Comptank...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
LandPride PFL1242 Pallet Forks (A50120)
LandPride PFL1242...
GMC 3500 Ambulance (AS IS)(NO TITLE) (A50774)
GMC 3500 Ambulance...
