2010 John Deere.. installing 3 point backhoe
/ 2010 John Deere.. installing 3 point backhoe #1
Randyrandt
Riverview
cub cadet 7260
We have a 2010 John Deere and want to install a backhoe. Can any one tell us where to connect the to hoses or the configuration of the hydraulic hoses. We have attempted it with no success.
Thanks for your time.
Randy
/ 2010 John Deere.. installing 3 point backhoe #2
You will likely need a "power beyond" kit available from your dealer. It will give you a set of hyd. connections at the rear for the backhoe. The power beyond hooks into the loader valve for constant hyd. flow.
Thanks Rob, I will check into that and keep you posted.
Randy
/ 2010 John Deere.. installing 3 point backhoe #4
Are you adding or already have a crankshaft driven hyd pump installed??
We wanted to tie into the existing tractor hydraulics. We have a loader on the tractor already.
/ 2010 John Deere.. installing 3 point backhoe #6
I seriously doubt a factory 2010 hyd pump will operate a BH very well.
/ 2010 John Deere.. installing 3 point backhoe #7
What model JD tractor are you attempting to install the BH on?
If 2010 is the model, here is the hyd.
Very low pressure
Hydraulics:
Type: open center
Capacity: 8 gal [30.3 L]
Pressure: 1150 psi [79.3 bar]
Valves: 1 or 2
Total flow: 11 gpm [41.6 lpm]
