2 post or 4 post vehicle lift ideas
   / 2 post or 4 post vehicle lift ideas #181
I would be interested in learning more about how you accomplished this.
this the under side. Ends drop into the rails where a slide jack wound go. I made 5 of them. I lay a couple of sheets on top and that gives a full flat deck on 4 post. Great for storing stuff When I put something narrow like tractor on lift I remove the ones not support tractor that opens up working room for tractor. I had a couple events at garage a it’s makes a big table
   / 2 post or 4 post vehicle lift ideas #182
Nice, I like the looks of that arrangement. My brother in law and I built some dollies that used C-channel, very similar to your platform assembly. I will keep this in mind in the future.
Thank you,
Doug
   / 2 post or 4 post vehicle lift ideas #184
Nice Code54 !!
   / 2 post or 4 post vehicle lift ideas #185
Thank you
   / 2 post or 4 post vehicle lift ideas #187
Here is a little better way to explain small off-roaders and how they fit. For reference, I also attached a photo of a RAM 2500 on the lift. With the aluminum inserts the lawn mower and rototiller can go across and I can change the oil on them pretty easily. It is a neat setup and seems to work pretty darn well.
With the siding jack system you can lift the rear of a vehicle, put jack stands under it and roll the jack to the front and lift it up (it has a steel lock system so you don't need jack stands with the air jack).
Hope this helps people with their decision on a 4 post or two post for their uses.
   / 2 post or 4 post vehicle lift ideas #188
By looking at the picture of your short bed crewcab on the lift, it definitely looks like I would need an extra long lift to accommodate my crewcab long bed wheelbase.
Would you agree with me on this question?
Doug
   / 2 post or 4 post vehicle lift ideas #189
Yes, Sir, that is correct. This version is the same length as the standard, but with wider posts and runners. I went with the wider shorter lift since this is as large of a truck as I ever plan on buying. I also didn't want to eat up too much garage space so that is why I skipped a longer lift. The wider part worked for me so I can put ATVs and the little SxS on it sideways.
For reference, the one I have is the Wildfire "Exotic"
2022 John Deere 5055E (A60462)
2022 John Deere...
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
iDrive TDS-2010H...
