1979 John deere 301a not going into forward
   / 1979 John deere 301a not going into forward #21
Smoking gun found (I believe ) the seals look pretty bad and note the rust around the inner lip.
The center bushing is worn to the copper. I am not sure what the spec is for this, or if the wear is acceptable, or replacement needed. Something to consider while it is apart.
   / 1979 John deere 301a not going into forward #22
I can see the old seal material needed to be cleaned but if it is smooth now I would stop sanding. The smaller the diameter the better I would think?
Update, parts on order and will be here Tuesday. If all goes well, should be up and running Tuesday/wednesday
   / 1979 John deere 301a not going into forward #24
Be careful it may take off forward so fast you could get whip lash. :)
Update: one of the seals they sent was incorrect but we figured out what happened and the correct one should be here Friday
Update: replaced the seals in the clutch pack this morning, put the forward clutch pack back together and reassembled the tractor. Runs like a champ!
   / 1979 John deere 301a not going into forward #27
Congratulations!!!!!!!!!!!! Now your neighbors might not think you've been drinking too much because now you can also go forward on your Yeller DEERE.
Here she is with her 8' York rake and 3/4 yard bucket
   / 1979 John deere 301a not going into forward #29
Nice Tractor, Good job!
Thanks, I'll give it some fresh paint in the spring, and will be installing the sunshade with-in the next couple days
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
2001 Diamond 20' Fuel Trailer, VIN: 5FWFS18241R000024, Tandem Axle, Asset# 27 (A59076)
2001 Diamond 20'...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
