1979 John deere 301a not going into forward
   / 1979 John deere 301a not going into forward
Sorry didn't proof read the last post. Was supposed to read *i haft to admit the seals look find to thee untrained eye
   / 1979 John deere 301a not going into forward #12
The disks appear to have wear on the splined area. The friction surface doesn't appear too bad. The sleeve in the housing where the seals ride doesn't appear too bad in the photo. Do you have a picture of the seals? Do you have the piston removed from the clutch drum?
Here are some pictures
I'll take it to work tomorrow and remove the piston. I have a press there
   / 1979 John deere 301a not going into forward #15
Ok, I got the clutch pack out, I haft to admit so do the seals ( to the naked and untrained eye) thoughts on the pictures of the discs?
Frictions disks should be .112-.118 thick. Separator plates .085-.095 thick. They are supposed to be slightly wavy.
Smoking gun found (I believe ) the seals look pretty bad and note the rust around the inner lip.
Piston ring
It's not rust on the lip, it's the rubber from the seal
   / 1979 John deere 301a not going into forward #19
Thanks for the photos. I know not to pull mine clutch as long as it will move forward. :)
Changing out the fluid about three times getting most of the water out helped our forward clutch a
lot. When we first got it in 2010 I had to travel in reverse to get it back up to the house after working if for a couple hours. I moved three buckets of dirt about 1/4 mile each round trip and on the third trip I add to let off the fuel to get it to lock up when in high range on taking off on pavement.
After changing fluids, filters and screen it always moves forward in Lo Range which is fine for me. On open road I can travel in Hi Range for about 10 miles in 7th or 8th (top) gear before it will not lock up the clutch on take off. Since I mainly use it around the place Lo Range is about all I need.
The old outer seal on the piston left a mess on the housing (see prior pics) so I scrapped off as much as I could w/ a razor then took 1000 grit sand paper and lightly sanded it smooth. Should this be ? Should I goto 1500 grit?
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2015 ISUZU NRR DEBRIS TRUCK (A57192)
2015 ISUZU NRR...
