1963 Ford 2000 (4 cyl)
   / 1963 Ford 2000 (4 cyl) #1
Randa
West Plains, MO
Ford 2000 (4cyl)
First time on the site, this looks like an informative area. Thanks for taking the time to read my post.
Working on restoring my grandpa痴 Ford 2000 (4 cyl). I致e got three questions. All three are very simple but nonetheless problems.
1. I am having problems with my box adjustment arm rubbing against the rear axel. The way I figure it I either have the wrong part or the hydraulic arm is too low. Is there another possibility? I am attempting to attach pictures.
2. I have converted the tractor to 12 volts. Do I need a voltage reducer at my distributor?
3. I purchased a temperature gauge, however, the tractor did not have one prior to restoration. Does the temp gauge go in the drain plug on the block?
Yes, I知 very green! Thanks for the help.
   / 1963 Ford 2000 (4 cyl) #2
Looks like your doing a nice job on that old ford. That arm looks like it can be adjusted forward so it's higher and the 3 point arm longer. Post a newer picture if your further along.
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
2011 CATERPILLAR 279C SKID STEER (A60429)
2011 CATERPILLAR...
Toro Sand Pro (A56859)
2014 CATERPILLAR CB24B DOUBLE DRUM ROLLER (A60429)
2014 CATERPILLAR...
