1845, Where to bleed pump after filter change
   / 1845, Where to bleed pump after filter change #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
It's time to replace the hydraulic filter on my 1845 and I can't find my manual. Also, I can't remember where to connect the host to bleed air from the variable displacement pump. Do I connect to the "T fitting" at the top of the pump as shown in the image below?
   / 1845, Where to bleed pump after filter change #2
Marrt,
On my 1445, it is a capped port on the side of the VVP, about 1/4"NPT equivalent in size.
All the best,
Peter
   / 1845, Where to bleed pump after filter change #3
That is where I connect on my 1845.
  • Filter Change.pdf
   / 1845, Where to bleed pump after filter change #4
I assume it is similar to the 1850. I am not on my computer right now but if you go to my web site, there are labeled pictures showing the location.
Ken
Thanks much guys. Exactly what I needed.
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
2020 DRAGON ESP...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
