1845, Where to bleed pump after filter change
   / 1845, Where to bleed pump after filter change #1
marrt
Northern VA
Power Trac 1845 and 425
It's time to replace the hydraulic filter on my 1845 and I can't find my manual. Also, I can't remember where to connect the host to bleed air from the variable displacement pump. Do I connect to the "T fitting" at the top of the pump as shown in the image below?
   / 1845, Where to bleed pump after filter change #2
Marrt,
On my 1445, it is a capped port on the side of the VVP, about 1/4"NPT equivalent in size.
All the best,
Peter
   / 1845, Where to bleed pump after filter change #3
That is where I connect on my 1845.
  • Filter Change.pdf
   / 1845, Where to bleed pump after filter change #4
I assume it is similar to the 1850. I am not on my computer right now but if you go to my web site, there are labeled pictures showing the location.
Ken
Thanks much guys. Exactly what I needed.
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2006 Wells Cargo 8x16 Trailer (A55973)
2006 Wells Cargo...
UNUSED FUTURE (100) PIECES OF 12'X3' GALVALUME (A57193)
UNUSED FUTURE...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
