Oil & Fuel 1840E Engine oil pressure light/engine failure lamp
/ 1840E Engine oil pressure light/engine failure lamp #1
Clark1183
MF 1840e
So both warning lamps came on at same time. Shut off and restart, lamps are off. After a few minutes, they both come back on. No change in performance, but too worried to keep going. Anyone else had this happen? Possible causes?
/ 1840E Engine oil pressure light/engine failure lamp #2
This same exact thing happened to me today 08/09/24…the tractor will not run above 1000 rpm. Did you resolve your issues?
/ 1840E Engine oil pressure light/engine failure lamp #3
What did you do to fix the problem?
/ 1840E Engine oil pressure light/engine failure lamp #4
