Oil & Fuel 1840E Engine oil pressure light/engine failure lamp
   / 1840E Engine oil pressure light/engine failure lamp #1
Clark1183
MF 1840e
So both warning lamps came on at same time. Shut off and restart, lamps are off. After a few minutes, they both come back on. No change in performance, but too worried to keep going. Anyone else had this happen? Possible causes?
   / 1840E Engine oil pressure light/engine failure lamp #2
This same exact thing happened to me today 08/09/24…the tractor will not run above 1000 rpm. Did you resolve your issues?
   / 1840E Engine oil pressure light/engine failure lamp #3
What did you do to fix the problem?
   / 1840E Engine oil pressure light/engine failure lamp #4
2016 Ram 5500 Chassis 4x4 ETI ETC37IH 37ft Bucket Truck (A56858)
2016 Ram 5500...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
8400 GALLON POLY TANK (A52708)
8400 GALLON POLY...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
23018 (A55758)
23018 (A55758)
