180 Mutilplier promblems
/ 180 Mutilplier promblems #1
MF300
Massey180
Problem: Mutilplier is always in low meaning something not working,
What i have checked: linkage from dash to case- ok; pressure from hydraulic line that routes to cooler= 5-10 psi; talked to local mechanic says no pressure means bad pump; or that the line that runs from pump up to check T on the line broke; so either a couple things to look at now no matter what i have to split the tractor line broke inside casing of tractor, new mutilplier clutch, or hydraulic pump.
Question is the pump that runs the multiplier the same as the the AUX hydraulic remotes or is it the main pump that runs tractor hydraulics
any info well be help full thanks
/ 180 Mutilplier promblems #2
I hope it's the Multipower your talking about.Yes it's the Aux pump that's used for the Multipower as well as any remote hydralics.Yes is could very well be the line that feeds the Multipowers control valve that could be split.I tried to scan and upload some pics from my manual but it's not working for me yet. .Larry
/ 180 Mutilplier promblems #3
Here's some scanned stuff from my manual hope it's what you need.Larry:thumbsup:
thanks,i just ordered a manual the other day still aint got it in yet, well im going to hope for the line being broke cause when i operate the hydraulic on the aux remotes the seem to have plenty of pressure so maybe that line just is not holding pressure for the multiplier... thanks again for the info
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
BUSH HOG SM60 DITCH BANK MOWER (A64278)
BUSH HOG SM60...
2023 JCB 270T SKID STEER (A65053)
2023 JCB 270T SKID...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2003 Jeep Liberty 4x4 SUV (A64557)
2003 Jeep Liberty...
