1610D head gasket
/ 1610D head gasket #1
kenr74
Amity, OR
Yanmar 1610D
I think I'm in need of a head gasket but wanted to confirm.
Runs/starts great but quickly overheats and pukes coolant. I put a bottle on the overflow hose and am getting lots of air bubbles. No coolant in the oil though. I just installed a new radiator cap to make sure that wasn't the issue but no change.
Sounds like a head gasket to me but any other ideas?
/ 1610D head gasket #3
One more comment - if you suspect compression is getting into the cooling system then there is a chance there could be water in a cylinder the next time you start it. So crank with the compression released for a few revolutions, to flush out any water, before starting it.
/ 1610D head gasket #4
Auto parts will rent or Borrow one. Radiator Pressure test Just attach it with the correct cap and see how much pressure the radiator does have in it. Should be around 13-16 PSI. your checking the pressure build up from a bad Gasket,Warped Head, Crack in Head/Block Etc.. real easy to Chk.. Harbour frieght, Walmart has kits cheap!!
/ 1610D head gasket
Thank you. It will be a while before I can dig into this but sounds like I have some work to do.
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2012 Kia Sorento SUV (A61574)
2012 Kia Sorento...
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
