1610 Fluids
/ 1610 Fluids #1
beltfed
Northern VA
Bobcat CT235
Can someone list the fluids (what type of each and how much) for the Iseki 1610.
As of right now I have no clue on where each fluid is located and will soon need to replace the Hydraulic fluid. I have a manual coming and will look through that but I hope someone already has the info needed. /forums/images/graemlins/cool.gif
/ 1610 Fluids #2
I believe the 1610 is the same as my 1910, the following is straight from my manual.
All locations are while your sitting in the seat. Qty's are in Qts/Litres
Engine oil, more than 70degF/20deg C SAE30, 32-70F/0-20C SAE20 or SAE10W/30, less than 32F/0C SAE10W, lhs of engine and takes 3.6/3.4.
Injection pump chamber, engine oil, rhs of engine and takes 0.12/0.11.
Fuel Tank takes 17/16 I am sure you've found it!
Steering box, gear oil SAE90, replenishment SAE140 no qty given.
Transmission, gear oil SAE90, 2WD 9/9.5 4WD 10.5/11.2, filler on top of tranmission with check plug on LHS of transmission.
Cylinder case, hydraulic oil (good quality) 5.8/5.5, filler with dip stick attached behind seat, between lifting arms.
Radiator Coolant 6.3/6
Front Axle 4WD only, gear oil SAE 90, 4.7/4.5
Hope this helps for now! /forums/images/graemlins/smirk.gif
/ 1610 Fluids
Thanks, that is just what I needed.
Any specific Hydraulic oil? Aren't there different types?
Appreciate it again. Now off to find the proper filters. /forums/images/graemlins/smile.gif
/ 1610 Fluids #4
I am using a Australian oil by Castrol, it would best to ask this question on the oils/fuels forum, for info on a local product to suit.
Regards
2018 Kia Rio Sedan (A64557)
2018 Kia Rio Sedan...
UNUSED JCT QUADRUPLE TINE BALE SPEAR (A65055)
UNUSED JCT...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
UNUSED FUTURE BS43-43" HYD MINI BOX BROOM SWEEPER (A65055)
UNUSED FUTURE...
2018 Ford Mustang GT Premium Coupe (A64557)
2018 Ford Mustang...
UNUSED JCT 72" HYD HEAVY DUTY BRUSHCUTTER (A65055)
UNUSED JCT 72" HYD...
