1610 Fluids
/ 1610 Fluids #1
beltfed
Northern VA
Bobcat CT235
Can someone list the fluids (what type of each and how much) for the Iseki 1610.
As of right now I have no clue on where each fluid is located and will soon need to replace the Hydraulic fluid. I have a manual coming and will look through that but I hope someone already has the info needed. /forums/images/graemlins/cool.gif
/ 1610 Fluids #2
I believe the 1610 is the same as my 1910, the following is straight from my manual.
All locations are while your sitting in the seat. Qty's are in Qts/Litres
Engine oil, more than 70degF/20deg C SAE30, 32-70F/0-20C SAE20 or SAE10W/30, less than 32F/0C SAE10W, lhs of engine and takes 3.6/3.4.
Injection pump chamber, engine oil, rhs of engine and takes 0.12/0.11.
Fuel Tank takes 17/16 I am sure you've found it!
Steering box, gear oil SAE90, replenishment SAE140 no qty given.
Transmission, gear oil SAE90, 2WD 9/9.5 4WD 10.5/11.2, filler on top of tranmission with check plug on LHS of transmission.
Cylinder case, hydraulic oil (good quality) 5.8/5.5, filler with dip stick attached behind seat, between lifting arms.
Radiator Coolant 6.3/6
Front Axle 4WD only, gear oil SAE 90, 4.7/4.5
Hope this helps for now! /forums/images/graemlins/smirk.gif
/ 1610 Fluids
Thanks, that is just what I needed.
Any specific Hydraulic oil? Aren't there different types?
Appreciate it again. Now off to find the proper filters. /forums/images/graemlins/smile.gif
/ 1610 Fluids #4
I am using a Australian oil by Castrol, it would best to ask this question on the oils/fuels forum, for info on a local product to suit.
Regards
UNUSED RAYTREE RMDM70-70" HYD DISC MULCHER (A65055)
UNUSED RAYTREE...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
6 Band Wood Barrel (A64557)
6 Band Wood Barrel...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
2008 Toro Workman Utility Cart (A64553)
2008 Toro Workman...
2022 EZ-GO ELITE...
