1530 power steering
/ 1530 power steering #1
tonyopitz
jennings fla
john deere 1530 YANMAR 169
i have a john deere 1530 with a loader that all of a sudden started get hard to steer to the left and then started leaking fluid from the steering colunm and the base of the steering box. I stopped moving dirt and parked it. havent pulled off the sheet metal yet but will do it tomorrow. What am I going to be loooking at and what would probably be the parts i will be replacing. ive worked on truck powerr steering gears but not a tractor, havent realy had tkis one long. any help would be appreciated.
tony
/ 1530 power steering #2
If I remember correctly there is a hydraulic line on the left side of the column. At the base. Maybe you will get lucky and find it's loose and leaking. With hard left steering problem sounds like it's in the column. Sorry I can't be more help.
/ 1530 power steering #3
Zebrafive
Sorry but the PS supply line is on RH(passengers)side.
More than likely the leak cure will be installing this kit(AT315816 KIT, OVERHAUL ADD 70.75 USD) which can be accomplishing by removing steering shaft with valves attached without needing to remove steering valve housing from tractor.
Hard steering in one or both directions could be simply a failed o-ring(parts key #4) or this valve(AR81610 BODY STEERING VALVE ASSEMBLY ADD 251.51)
Thanks alot, I sure appreciate the great reply.Is the dealer the best source for this part or is there another online parts house that would stock these parts?, again thanks alot
Tony
/ 1530 power steering #5
Your right TXjim, it's the other left (right) for the hydraulic connection :eek: I should not have gone from memory :eek: Line comes up from priority valve on the RIGHT side of the tractor.
I've never been into the steering column for repairs, is this a special tool, dealer job? If so I'd let them do it.
/ 1530 power steering #6
Zebrafive
Technically the PS line attaches to a line leading from main hyd to the priority valve. PS line is parts key # 1 and supply line is parts key # 6. The only special tools required are a spanner wrench and a long pick to R&R the 6 larger o-rings. I've used a pipe wrench or large slip joint pliers in lieu of spanner wrench
I went out and took a better look at it after pulling the sheet metal and to find out what I could see. I looked in the bottom ,didnt see any lines broken or leaking, it was leaking out of the colunm,around the base and coming out the top of the colunm.
it appears to be fairly straight forward once I can figure out the procedure. does the whole assembly come out as a unit or does the housing slip off of the shaft? it doesnt appear that the steering colunm has been off in a while I
it appears to be fairly straight forward once I can figure out the procedure. does the whole assembly come out as a unit or does the housing slip off of the shaft? it doesnt appear that the steering colunm has been off in a while I guess it was just time for it to let go.
Thanks , Tony
/ 1530 power steering #9
You can remove steering wheel,then large adjusting nut,set steering wheel back on shaft and turn steering wheel to the left and the shaft and valves will come out the top of housing. No need to remove housing to change the 6 big o-rings.
thanks a million, Ijust ordered a shop manual,should have done it when I got the tractor.Iwill try to get the kit from the dealer tomorrow.
Im a little confused on the tractor being a 1530, the engine ID plate says made in France,I thought the 1530 was made in Germany I cant seem to reference the numbers anywhere, type-3164DL-13 SERIES- 198005CD, the tractor serial number is covered up by the loader frame.
also it has 38 inch wheels ,thought it was supposed to have 28s and has 2 7/8 adjustable axles, Iguess I need to get a little better educated on these tractors it has 1530 decals on the hood . In any case Ido like the tractor althuogh I have only had it a short time, it is much more than the yanmar that I have and handles the loader just fine starts right up every time.
Once again thanks for the help,this is a excellent website.
Tony
/ 1530 power steering #11
The engine was in fact built in France. Deere has an engine factory in Saran, France. The engines were then shipped to Germany to be installed in the 1530. The engine serial plate 3164DL, stands for 3 cylinder, 164 cubic inch, diesel. There were two axle configurations. The adjustable axle you have and also flanged axles were available. The rear wheels could have been 38 inch, 28, 24, or even 16.1 inch turfs.
that clarifies everything,thanks alot
tony
/ 1530 power steering #13
Tony
38" rear wheels with rack & pinion axles was an option on 1530's. This parts schematic is from a 1530 parts catalog
2022 EZ-GO ELITE...
3ft American Flag Metal Rooster (A65583)
3ft American Flag...
2019 K&K Equipment Trailer, VIN # 1K9PE2026KA175452 (A65563)
2019 K&K Equipment...
Hedge Posts (A65640)
2020 Chevrolet Traverse SUV (A64557)
2020 Chevrolet...
Caterpillar 318BL Excavator (A65579)
Caterpillar 318BL...
