15 acres, which tractor?
/ 15 acres, which tractor? #21
We've got 14 or so acres and have a gentlemen that hays it for the hay. So I guess it pays off. We still have to mow some of it, mostly around the edges as it's not fenced well and trees dot the field with a couple soft spots. The JD 1050 is about 33 pto hp with a 5ft cutter is about minimum if one is to mow the whole area IMO, as it takes 6-8hrs depending on growth.
/ 15 acres, which tractor? #22
Nothing really new here but here's my 2 cents anyway - We have 10 acres and 4 horses. Have an L2500 gear tractor. Bought it new with loader and boxblade for $14300 in 1999 delivered to my door. 25 hp and I wouldn't want less. There are times I would have liked MORE but it would have been a luxury, not a necessity. Have never wanted a smaller one. I would look for 25 -30 hp for your use as you will be putting in fence (need post auger), bushogging, maybe putting in an outdoor arena, moving baled hay, moving manure etc. HST is something I wished I had at times (mainly when doing loader work) but the gear was about $1500 less so that was my choice. I would also reccomend going with the R1's. I've never wished I had LESS traction!! /w3tcompact/icons/smile.gif
/ 15 acres, which tractor? #23
Well your sitrep sounds a bunch like mine. I ended up on an <font color=orange>Orange</font color=orange> B7800. We now have a horse, looking for more, ten acres, barn, etc. etc.
How did I get to the tractor, well I looked at this board for close to a year. There was BX fever back then. And I thought that was it for me. Until.... I went shopping. Until.... I started sitting on them, until.... I looked at my property numerous times and thought out what I wanted to do.
Move Manure - FEL and Spreader
Cut grass, Bushhog - Lawnmower and Bushog
Spread Stuff - FEL, Rake, Spreader, Blade
Plow snow - FEL and blade
Not kill myself - ROPS and seatbelt
Traction - 4WD
Power - 25-40HP
Price - 12 - 18k
Dealer - Unmatched quality
Final write off --------- wife.
Go not think about it for a while, then do the steps all over again. When I had the class of tractor nailed, I started going to dealerships in my area. The good thing you have done is read this board. The information is beyond compare.
Best of luck in your search. Remember IMHO a few thousand more over 20 years ain't much. Get what you NEED, get what you WANT. /w3tcompact/icons/smile.gif
Here is the <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=owning&Number=225690&page=0&view=collapsed&sb=5&o=0&fpart=1#Post227882/> B7800 in Action</A> link.
HTH
-Mike Z.
Hazmat-
I have not had a chance to test drive any tractors yet. Before I get to that stage I would like to have a pretty good idea of what models I should concentrate on.
Until we recently purchased the property, there was a farmer who collected hay off the land. If he is still interested in collecting it, I have no problems letting him do it on 10 acres. If not, I very well may have to mow / brush hog it myself. The property is very flat and rectangular. There are no trees on it, so mowing should be pretty easy.
Dan
/ 15 acres, which tractor? #25
Dan,
<blockquote><font size=1>In reply to:</font><hr>
Just moved here from the city. Can I cut 15 acres with my push mower?
<hr></blockquote>
Of course you can, /w3tcompact/icons/smile.gif question is do you want to?
Whereabouts in our great commonwealth art tho?
-Mike Z.
Mike-
I moved from the heart of Cascades (small yards and houses stacked on top of each other) to Purceville. We are having a house built which should be done in the next 3 months, so I am really starting to focus on what I will need to care for the property. The property has a 4 rail fence all around it, so that is one less thing I have to worry about.
/ 15 acres, which tractor? #27
<font color=blue>Can I cut 15 acres with my push mower?</font color=blue>
If your a *********, I suppose ya can... /w3tcompact/icons/grin.gif
all in fun...
/ 15 acres, which tractor? #28
<font color=blue>Can I cut 15 acres with my push mower? <font color=black>
You probably won't want to do it more than once a year. By the time you get it cut once, winter will set in and you can start over next summer /w3tcompact/icons/laugh.gif.
With a new house, I would be willing to bet you will be doing some landscaping (flower beds, shrubs, walkways, etc.). The tractor will really come in handy with all of these projects and any more the wife can dream up. Once she sees how much you can do with it, she will be glad you got one too. /w3tcompact/icons/wink.gif
/ 15 acres, which tractor? #30
i am going to try and put this in it's simplest form, some may not agrre but is MHO. hp is only relevant to the physical size of the tractor. my b2400 has plenty of power, but due to the fact that they must design the hydraulic to match the size of machine,u can't lift more than is safe for the tractor. they could buid a b2400 with hydraulics that would lift more , but it would probably not be good for the machine. it would exert more force and strain than that size frame could handel. i know this is not very sientific, but i hope u will get my drift.
/ 15 acres, which tractor? #31
I have noticed that hydraulic pump flow rate is not discussed here as much as HP. To me pump capacity is very important with an FEL. bcs
/ 15 acres, which tractor? #32
Dan,
Welcome to TBN.
As the others have mentioned 25hp is a good bottom end number. We bought used, but got a great deal on a 34 (pto) hp 2wd w/ a FEL and brush hog. I can testify of the previous statements that you never want to go smaller.
Just as important as HP ratings is the dealer. IMHO, the color of your tractor is less important than the service that the dealer will give you. Other TBN'ers will attest to the good and bad experiences w/ their dealers. I would suggest finding people who have purchased tractors from each of the available dealers and ask them how the service has been.
Clint
/ 15 acres, which tractor? #33
I will be the outlaw here /forums/images/graemlins/cool.gif
I have 40 acres with a similar mix to your 15, and I wouldn't recommend approaching your problem the way you are. First, throw out any thoughts of the BX. An overpriced toy for your property. You have two distinct needs, and like most things in life, the BX does both with weak results. With a portion of your $15k (and dont get talked into spending more) you should buy a decent quality lawn tractor. I would recommend used, but it doesnt need to be if you arent handy. This machine will excel at mowing around the house, compact enough to get close and light enough to mow on soft ground without compaction. Plus your wife will be more apt to jump on an tool around on an LT. Let's assume you spend $2 grand on this, take the remaining $13 and look for a lightly used L series or other brand similar with 25-30 hp and a loader. With a little shopping (which is fun /forums/images/graemlins/laugh.gif) this is not too hard to find.
By doing this you will be much better prepared for future uses (backhoe, small haying equipment, moving bales around with FEL, etc) You will also avoid a hit in depreciation when and if you sell, since you bought used in the first place.
I think the BX is great for someone with 5 acres and a lot of open mowing. It is a handy little rig. But with real property and the possibilities of lots of projects down the road, dont spend $15k on something relegated to the lawn!
/ 15 acres, which tractor? #34
Dano33,
Welcome to TBN! /forums/images/graemlins/smile.gif
My two cents is to forget about how much money you have
or don't have to spend. /forums/images/graemlins/shocked.gif Forget about the BX2200
or any other tractor you might have thought about. /forums/images/graemlins/confused.gif
Figure out what has to be done on the property. Or what
might have to be done. Go read the Proejcts and Attachment
discussion areas to see what people are doing with their
eqiupment. Right now you might think you can only do A, B,
and C with your tractor but if you start reading you will hear
about tractors doing work you never would have thought
possible.
In 1999/2000 I was in your shoes thinking about spending the
same amount of money. I ended up spending MUCH more than
my budget! /forums/images/graemlins/crazy.gif But its been worth every cent.
The one thing to keep in mind as you work your way through
this quadry is that time is money and money is time. There
is always a bigger tractor or attachment out there that will
do the job quicker and better than what you have or want.
So the question becomes is it worth the extra dollars? Is it
worth X thousands of dollars to save you Y amount of time?
You need to mow. But what kinda of mowing? Rotary cutting
for the 10 acres and the road right of way? Or can you just
use the mid mount mower? My neighbor has a BX2200. He
tried to help me out by mowing my right of way. I asked him
NOT to since I did not think his equipment could handle the
rocks, wood, and stumps. He mowed a few hundred feet and
was hearing to many things bouncing around under his tractor
so he figured I was right and stopped! /forums/images/graemlins/blush.gif
But if your right of way is in better shape than mine the
BX2200 can work just fine.
Are you going to have to put in posts for fences? Will it be
cheaper for you to do the job or pay someone?
Would you want to use the tractor to generate power during
power outages? Will the tractor provide the power you need?
Do you need a wood chipper?
Do you want to till or plow a garden? How large?
Do you have to do landscapping around the house?
If you get a tractor you need an FEL as far as I'm concerned.
So just go ahead and get past that decision. But do you need
to GRAB things with the FEL?
You have a long road to maintain. So you need a box blade
or a blade. I prefer a box blade.
This is just to start. /forums/images/graemlins/grin.gif
Good Luck! /forums/images/graemlins/smile.gif
Dan McCarty
/ 15 acres, which tractor? #35
Congrats on the farm.
I did something similar. I moved from a little 1/4 acre lot in a neighborhood to agricultural land. In a rush, I bought a tractor that was a tad bit too small foo all I needed it to do. But I must say.. any tractor is better than no tractor at all.
Since then I've found one that is more fitted to my needs. In my opinion, buy the biggest you can affored, with the future in mind.
Perhaps you may sacrifica a few bells and whistles for size and brawn.. ( unless you want it for the bells and whistles! /forums/images/graemlins/grin.gif )
Good luck either way.
Soundguy
SteveM
You got my vote! My thoughts exactly. I have twelve acres and after much thought did what you suggested. Some times you need two pieces of equipment to do it right.
Based off of your responses, it looks like I have some shopping to do. I am hoping to get out to my local John Deere and Kubota dealer this weekend. Both dealers have been great to talk to and have know my property. Both of them have recommended a 25+ hp tractor as a minimum. They have been very informative and have encouraged me to get out to their dealerships and test drive a few. If the weather holds out, I will try to get this done on Sat. I have also gotten some good info regarding used trators for sale, so that may be an option as well. I also got contacted by a Kioti dealer who was very pleasent to talk to. This dealer is located much further away, but I don't think it would hurt to go see what he has to offer. With the information I am picking up on this board combined with your real world feedback, I feel much better about knowing what I am getting into. Thanks for the replies and please keep sending your suggestions.
/ 15 acres, which tractor? #38
Danno,
I have two acres. I purchased a TC21D with a FEL and a 60" MMM. Now most would people tell me that is plenty. My dealer told me it wasn't but I didn't listen to him. I had two reasons for being dissapointed. 1, was the hills on my property, it was way to dangerous as far as tipping over. 2, The FEL did not allow to pick up much stuff without fear of tractor tipping over, even on flat land. I could have the bucket two feet off the ground and if I turned the steering wheel fairly sharpe the tractor would start to tip over. So if your going to be working with manure which is heavier than dirt you would have the same trouble with a smaller tractor.
So I bit the bullet and took the tractor back, my dealer charged me a small amount for the upgrade and gave me the original price that he quoted my on the TC29D that I ended up with. This has made a big difference but still wished I went to the TC33D. I got a FEL and a 72" MMM on my 29 and I can mow around the yard just fine. I make one pass with the push mower around the yard, 5 minutes and then finish with my 72" MMM. And in my case I keep the wife off of the tractor, seat time is precious to me. I unwind when I am on the seat. But as everybody has said, make sure its big enough even if buying a lawn tractor right now to get bigger it is a good idea. I am not selling Blue, there is really good machines out there but none is no good without support. Also make sure you have fun and keep everything safe.
Murph
/ 15 acres, which tractor? #39
as someone said before me, 1 machine can not do all thighs well. i use a 5.5 hp walk behind, for close stuff, and an 18hp gt for the rest of my yard lawn, and then the b2400 for cutting the wide open spaces, removing snow, moving dirt, dragging trees,etc. check your options well.
/ 15 acres, which tractor? #40
Dano,
Just less than a year ago I was hot on the 'bota trail, ready to write a check for 15K just like you and convinced bota, deere or another conventional tractor would be the right choice for our place. I stumbled onto TBN and asked a few questions that changed my perspective in ways I could never have guessed (it was mostly da Rube's and MossRoad's fault).
The best thing to do at this juncture, IMHO, in addition to kicking tires, is to spend ample time looking through the TBN discussion forums. Almost any question or issue you can imagine has been posted here with sometimes witty, generally fabulous, and thoroughly experienced responses.
From what I gathered, I would opine that no one person, dealer or otherwise can be your "travel guide"...you just need to figure out what responses resonate with you for whatever reasons are most important to you.
The research stage you are in right now can be a lot of fun, second only to seat time. /forums/images/graemlins/smile.gif Get lots of brochures and web addresses to pore over, make some lists, ask lots of questions and Enjoy the process!
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2007 International 4400 S/A Dump Truck (A61573)
2007 International...
2003 GEELY JL50QT-14 SCOOTER (A63291)
2003 GEELY...
2013 Ram C/V VAN (A61574)
2013 Ram C/V VAN...
2011 Terra Riser 300D-SA Fire Plow Tractor Attachment (A61572)
2011 Terra Riser...
Year: 2016 Make: Mercedes-Benz Model: SLK-Class Vehicle Type: Passenger Car Mileage: 116,700 Plate: (A61574)
Year: 2016 Make...
