116h pto (pretty ticked off)
/ 116h pto (pretty ticked off) #1
blalbrec
Saginaw, MI
John Deere
I have a real head scratcher, I have a 1983 116h with and opposing twin briggs. I have been chasing a problem releated to the pto. I can run ithe tractor for hours (just finished grading the gravel driveway) but when I engage the pto for mowing it stalls out. It has been getting proggressively worse, as of last fall I could mow for about 30 minutes and it would "overheat" the pto and stall, after a minute to cool, I could fire it up just fine and run it without the pto, as soon as I engaged the pto it would run for several minutes and stall again. When it stalls, I have power, will not crank, no lights, nothing. After a minute I hear a small click below the battery, as soon as it clicks, it will start just fine. I replaced the circuit breaker, thinking that was it, nothing. I checked the coil and it checked out fine. I am stuck. Any help would be greatly apprecciated. Thanks in advance.
/ 116h pto (pretty ticked off) #2
Electric PTO? If so, sounds like it needs replaced.
It was working for a while, just today it started to stall when the pto was engaged. Is it possible that it is out of adjustment. Would a stator failing be an issue?
/ 116h pto (pretty ticked off) #4
Or a bearing gone bad?
Sounds like it could be a number of things.
:welcome: to the forum.
Thanks for the welcome. I will check the air gap on the pto when i get back out to the barn. Thank you for the replies.
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2016 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2016 Nissan...
2011 JLG E400AJP BOOM LIFT (A60429)
2011 JLG E400AJP...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
KMC 4 ROW BED SHAPER (A60430)
KMC 4 ROW BED...
