116h pto (pretty ticked off)
/ 116h pto (pretty ticked off) #1
blalbrec
Saginaw, MI
John Deere
I have a real head scratcher, I have a 1983 116h with and opposing twin briggs. I have been chasing a problem releated to the pto. I can run ithe tractor for hours (just finished grading the gravel driveway) but when I engage the pto for mowing it stalls out. It has been getting proggressively worse, as of last fall I could mow for about 30 minutes and it would "overheat" the pto and stall, after a minute to cool, I could fire it up just fine and run it without the pto, as soon as I engaged the pto it would run for several minutes and stall again. When it stalls, I have power, will not crank, no lights, nothing. After a minute I hear a small click below the battery, as soon as it clicks, it will start just fine. I replaced the circuit breaker, thinking that was it, nothing. I checked the coil and it checked out fine. I am stuck. Any help would be greatly apprecciated. Thanks in advance.
/ 116h pto (pretty ticked off) #2
Electric PTO? If so, sounds like it needs replaced.
It was working for a while, just today it started to stall when the pto was engaged. Is it possible that it is out of adjustment. Would a stator failing be an issue?
/ 116h pto (pretty ticked off) #4
Or a bearing gone bad?
Sounds like it could be a number of things.
:welcome: to the forum.
Thanks for the welcome. I will check the air gap on the pto when i get back out to the barn. Thank you for the replies.
2016 John Deer 5075E (A60462)
2016 John Deer...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
1999 Thompson H3 S/A Towable 6in JSV Dewatering Pump (A59228)
1999 Thompson H3...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
