10K dump trailer build
/ 10K dump trailer build #21
I’d use plastic but drill small drain holes on the bottom side.
Maybe BEFORE you run the wire through.
/ 10K dump trailer build #22
That would be me...….
/ 10K dump trailer build #23
It’s just possible that the twist drill would grab the bundle of wires, wrenching the connection out of the right turn signal fixture and two of the four clearance lamps on the same side!
I’m just speculating of course .....
/ 10K dump trailer build #24
Plastic pipe expands and contracts in heat and cold. Something to consider
/ 10K dump trailer build #25
Of course.
What痴 your thoughts for using plastic, any trailers I致e had seen or worked with that have conduit for the wires were all metal? I壇 go with HREW or even black pipe for no more then you need.
I see too much corrosion with anything metal so figured the grey plastic would work.
Well I went and picked up the new axles today, I am hoping to get the trailer back into the shop tomorrow morning to finish up the welding on the top and then start the dump body portion, that should go fairly quickly. I still have to pick up tires and wheels so I'm not sure when exactly I will be able to get the axles installed, I'm debating flipping it back over to do the swap, we'll see. When I flipped it over the other day it actually went pretty well. I only put tires on the front axle thinking it would be easier to maneuver.
WOW! I can't believe my last post was Feb 19th.
Just some updates. I have the axles mounted, got new tires and wheels, cylinder is in, hydraulic unit still needs a place to sit under the bed and also the battery. I have the dump bed frame built and hinges on, it tilts to 42.5 deg which I think will be fine. Cylinder is a 5" bore x 30" stroke, should dump anything. (I know, famous last words)
Life kind of got in the way, between the COVID and the first week in March my wife fell and broke her hip then 8 weeks ago she fell and broke her clavicle. I am getting the bedsides formed out of 11 ga, the place I am going through has been a bit lax, between the COVID and he is busy etc. etc. I have a short video of it tilting if I can figure out how to link it.
dump trailer test - YouTube
Now I can't work on it in my garage so hopefully when the sides are ready I will put it in his shop and finish it up there.
/ 10K dump trailer build #29
Sorry to hear about your wife's mishaps and happy to see you are back on the build!
/ 10K dump trailer build #30
Sorry to hear of the injuries to your wife!!! Hope things will turn around soon!!!!
/ 10K dump trailer build #31
It has just never happened before so it kind of bummed me out. I want a new bigger more powerful welder anyway but not at the moment.
I am finishing up a job today so I should be able to get back to the build in a couple of days.
The next project on deck is 20' car/tractor trailer.
Its the welders way of saying you need a beer break
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2018 MACK CXU (PINNACLE) (A60736)
2018 MACK CXU...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
