1050 headlights ,SEATBRACKET bolts!
/ 1050 headlights ,SEATBRACKET bolts! #1
jeewhiz
N.Y.
cub 1050
Do they really need to be on at all times? Other than safety!would it help my economy if I unplugged them! GAS isn't getting any cheaper! I also would like to let other cub owners know there is a issue with seatbracket bolts being too long! They go through the bracket into the GASTANK! I solved problem with washers!I discovered this problem when a hairpin fell out on the deck! Other than that she has treated me well SOOO Far! 60 hrs and counting!
/ 1050 headlights ,SEATBRACKET bolts! #3
Good tip for the seat attachments. You wouldn't see any measurable fuel economy gains by turning off the headlamps. My bets are CC went to the full on headlamps for 2 reasons. 1) is cheaper than running a switch, relay, etc.. 2) It's helps the safety image a bit. My 2544 looks like it's *winking*. /forums/images/graemlins/wink.gif I've had one blown headlamp since about 20hrs. /forums/images/graemlins/tongue.gif
Joel
/ 1050 headlights ,SEATBRACKET bolts! #4
Joel
/ 1050 headlights ,SEATBRACKET bolts! #5
I installled aswitch on the headlights.
/ 1050 headlights ,SEATBRACKET bolts! #6
/ 1050 headlights ,SEATBRACKET bolts! #7
dqdave1 - Good idea. Did you just extend the headlight wires and use an inline switch, or a relay off of another hot source?
Thanks!
/ 1050 headlights ,SEATBRACKET bolts! #8
Thanks!
/ 1050 headlights ,SEATBRACKET bolts! #9
Picked up a switch rated at 20 amps and and looped the hot lead to the lights through the switch. Took about an hour to do.
/ 1050 headlights ,SEATBRACKET bolts! #10
3269 (A63117)
3269 (A63117)
Kicking Bull Statue (A64127)
Kicking Bull...
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
12x20 Car Port (A65640)
12x20 Car Port...
