1050 headlights ,SEATBRACKET bolts!
   / 1050 headlights ,SEATBRACKET bolts! #1
jeewhiz
N.Y.
cub 1050
Do they really need to be on at all times? Other than safety!would it help my economy if I unplugged them! GAS isn't getting any cheaper! I also would like to let other cub owners know there is a issue with seatbracket bolts being too long! They go through the bracket into the GASTANK! I solved problem with washers!I discovered this problem when a hairpin fell out on the deck! Other than that she has treated me well SOOO Far! 60 hrs and counting!
   / 1050 headlights ,SEATBRACKET bolts! #3
Good tip for the seat attachments. You wouldn't see any measurable fuel economy gains by turning off the headlamps. My bets are CC went to the full on headlamps for 2 reasons. 1) is cheaper than running a switch, relay, etc.. 2) It's helps the safety image a bit. My 2544 looks like it's *winking*. /forums/images/graemlins/wink.gif I've had one blown headlamp since about 20hrs. /forums/images/graemlins/tongue.gif
Joel
   / 1050 headlights ,SEATBRACKET bolts! #4
Joel
   / 1050 headlights ,SEATBRACKET bolts! #5
I installled aswitch on the headlights.
   / 1050 headlights ,SEATBRACKET bolts! #6
   / 1050 headlights ,SEATBRACKET bolts! #7
dqdave1 - Good idea. Did you just extend the headlight wires and use an inline switch, or a relay off of another hot source?
Thanks!
   / 1050 headlights ,SEATBRACKET bolts! #8
Thanks!
   / 1050 headlights ,SEATBRACKET bolts! #9
Picked up a switch rated at 20 amps and and looped the hot lead to the lights through the switch. Took about an hour to do.
   / 1050 headlights ,SEATBRACKET bolts! #10
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
LOT: (2) Shelves of Komatsu Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (2) Shelves...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 International 4300 Reefer Truck (A56438)
2012 International...
2017 Skytrak 10054 10,000lb 4x4 Rough Terrain Telehandler (A56857)
2017 Skytrak 10054...
Mini Margaritaville Truck (A55853)
Mini...
