1050 headlights ,SEATBRACKET bolts!
   / 1050 headlights ,SEATBRACKET bolts! #1
jeewhiz
N.Y.
cub 1050
Do they really need to be on at all times? Other than safety!would it help my economy if I unplugged them! GAS isn't getting any cheaper! I also would like to let other cub owners know there is a issue with seatbracket bolts being too long! They go through the bracket into the GASTANK! I solved problem with washers!I discovered this problem when a hairpin fell out on the deck! Other than that she has treated me well SOOO Far! 60 hrs and counting!
   / 1050 headlights ,SEATBRACKET bolts! #3
Good tip for the seat attachments. You wouldn't see any measurable fuel economy gains by turning off the headlamps. My bets are CC went to the full on headlamps for 2 reasons. 1) is cheaper than running a switch, relay, etc.. 2) It's helps the safety image a bit. My 2544 looks like it's *winking*. /forums/images/graemlins/wink.gif I've had one blown headlamp since about 20hrs. /forums/images/graemlins/tongue.gif
Joel
   / 1050 headlights ,SEATBRACKET bolts! #4
Joel
   / 1050 headlights ,SEATBRACKET bolts! #5
I installled aswitch on the headlights.
   / 1050 headlights ,SEATBRACKET bolts! #6
   / 1050 headlights ,SEATBRACKET bolts! #7
dqdave1 - Good idea. Did you just extend the headlight wires and use an inline switch, or a relay off of another hot source?
Thanks!
   / 1050 headlights ,SEATBRACKET bolts! #8
Thanks!
   / 1050 headlights ,SEATBRACKET bolts! #9
Picked up a switch rated at 20 amps and and looped the hot lead to the lights through the switch. Took about an hour to do.
   / 1050 headlights ,SEATBRACKET bolts! #10
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
1026A (A58374)
1026A (A58374)
Sterling T/A Ox Bodies 16Yd Dump Truck (A56858)
Sterling T/A Ox...
telescope boom (A56857)
telescope boom...
CASE MXM 190 (A58214)
10222 (A56858)
10222 (A56858)
