1025R Normal Engine Temp
   / 1025R Normal Engine Temp #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I bought an almost new 1025R back in December; the engine temp barely reaches 1/4 off the stop. I’m not running it for that long, nor am I running it beyond 2,500rpms, and it’s been relatively cold in Virginia. I don’t know much about the power unit in these... something to be concerned about, or not?
   / 1025R Normal Engine Temp #2
I have a 2018 2025R (same engine as your 1025R) and in winter, the temp gauge is about the width of the needle off the post. In 80 degree summer, it may get 2-3 needles worth. The only people that have problems with the temperature are those with heated cabs. They either block most of the radiator with cardboard or they change the 160 degree thermostat to a 180 degree one to get more heat in the cab.
   / 1025R Normal Engine Temp #3
If you don't have the cardboard in front of your radiator try blowing air through it from the back to the front. Dust tends to collect in the fins and reduce cooling efficiency.
   / 1025R Normal Engine Temp #4
No concern at all. Replace the 160 Stat with the 180. I'm happier with how it runs.
2003 Buick LeSabre 4 Door Sedan (A49339)
2003 Buick LeSabre...
2017 GMC Yukon XL 4x4 SUV (A46684)
2017 GMC Yukon XL...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A49346)
2025 JMR 36in...
2017 Peterbilt 567 Tri-Axle Dump Truck (A46683)
2017 Peterbilt 567...
2009 Ford F-550 4x4 11ft Flatbed Truck (A46683)
2009 Ford F-550...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
