100 HP Plug In EV 4WD Tractor
/ 100 HP Plug In EV 4WD Tractor #1
daugen
Epic Contributor
New Hope PA
in between now
First Look: Ferrari LaFerrari - Automobile Magazine
If Ferrari can get 160hp in one motor for their supercar,
why can't we have a "de-tuned" 100 hp version for our 4, 5, 6 series JD tractors, or equiv...,
and say goodbye to diesel?
I think this is just around the corner for us. Battery weight could easily replace lost engine mass, and
no waiting for AC/DC power. And a huge reduction in maintenance. And likely cost per hour of use.
i'm guessing that Fendt or maybe even JD is researching this already. Would require a major shift in thinking, but
then the large ship marine industry figured this out a long time ago.
The picture of the powertrain still makes me wonder a bit. First I thought those hoses were hydraulic, then electric? where's the motor?
then back to hydraulic, that square box just didn't look "electric" to me, whatever that means.
I bet Lamborghini is working on this too, those two competitors don't seem to like to be one-upped at all.
Likely all gets back to the cost of the kw. The motors are available now, battery tech is always the issue it seems.
Well, how about if we want more weight? Pile on the batteries, who cares, make your weight do double duty.
I'll always get diesel on my hands, I love the old stuff, but now I'm starting to itch for the new.
Not like one has to give up anything. Unless they consider our polluting diesel tractors enemies of the state...
And then some Bloomberg grand children will come around in Federal roll offs and haul them all away.
Sounds like a bad dream.
So, if the electric companies can generate power less expensively than we individuals can, assuming we don't want acres of solar panels,
I wonder if we could get a "farm" rate? Uh, remember mr politician, you like to eat don't you?
Considering how unreliable power is in our area in storms, I think the market for backup larger gens is a strong one. Independent operation is expensive but I'd hate to be that dependent upon one source for all that would run on my farm.
Let's see, I get in my MEV9000 Kubota, and the battery level is low, no juice last night from the grid.
Better turn on the gen...
I grew up reading science fiction avidly, and have some experience in electronics. I really think in our lifetimes, even us somewhat over the hump guys,
we are going to see viable large frame tractor EV operation.
Now if you had an extra large cab roof with a retractable solar panel, like on the satellites, you could make some power while you went round and round.
Until the extension arms broke when you dropped a wheel in that ditch... Better be made tough.
Are you ready?
/ 100 HP Plug In EV 4WD Tractor #2
There is a basic physics problem with your proposal. Nice try though.
At low power demand (sipping rather than gulping), lead-acid batteries tend to hold about 30–40 Wh per kilogram (one Watt-hour is equivalent to 3600 J, or 0.001 kWh of energy). Ni-MH batteries score 45–60 Wh/kg, and Lithium-ion gets about 120–180 Wh/kg. Part of the reason for Li-ion’s better performance is that lithium itself is lightweight; by volume lead-acid has about 40% the capacity of Li-ion. Gasoline, at 36.6 kWh/gal, has a specific energy of 13,800 Wh/kg. Off the charts!
http://physics.ucsd.edu/do-the-math/2012/08/battery-performance-deficit-disorder/
thanks.
I'm sure there is. This may need to wait for hydrogen or some other tech to prove itself, but
my point was I think it's coming. Yes, gasoline is sure explosive compared to LIion, which is why we love it.
Natural gas too. I was given a large tractor coffee table book for xmas and there are lots of older LPG powered tractors,
with their familiar tanks sticking out. Maybe with all the "frack'in" LNG being produced, we should look first to LNG. But again,
gas does have its power. How does diesel compare, which at 100hp levels is more likely?
I drove a 2013 Lexus ES300H recently, basically a gussied up Avalon Hybrid. The golf cart sensation is a little unnerving at first, when one is just moving around a parking lot, with the radio off. Very, very quiet. My wife didn't like the car, though I sure liked the 40mpg.
It was my first experience with hybrids/EV as I knew I was not a Prius guy. But this car on EV mode made me think of being in my Kubota
taking a load of brush down to the storage area only hearing a quiet whirr and some lonesome Southern sweetheart singing to me on the radio...ahem. I had tinnitus early on in life and it has made me very jumpy at loud noises, and sensitive to noise in general. So a quiet cab
would be very appealing to me. And one of those Bose mini speaker surround systems... Since my factory radio just conked out, and yes I checked the fuse, I might just replace the thing with an inexpensive Kenwood or Sony which will sound light years better since I already put in better speakers. If there is so much engine noise that one has to crank up the stereo to hear or drown out the engine noise, it just gets too loud for me.
I probably should drive with a nice set of active headphones on, but I'm still pretty new to my equipment, so I want to hear the equipment running too. And a mower can be super loud too...
I was thinking of an EV tractor pulling a five bottom plow, with a mike placed on the three point.
What a lovely symphony of noises as the earth is opened up.
/ 100 HP Plug In EV 4WD Tractor #4
Are you ready?
Did you read the article? This isn't a plug in hybrid or even a car that can run electric only. It's a dual power car where it gets power from both a gas engine and when needed an electric. This gives it a combined output of 951HP. It generates power I believe under braking and stores it till needed. An electric motor can run for a long time without a load on a battery, but under load it draws down very fast. We have electric fork lifts at work. The battery packs take up a large amount of space and don't last very long vs a small propane cylinder. With a fork lift the extra mass is good and we aren't trying to go very fast or pull a plow. I also work on machinery with a lot of the tech used to make these things possible.
The headlining news is that the mid-mounted 6.3-liter V-12 engine is augmented by a hybrid drivetrain. Two electric motors -- one coupled to the seven-speed dual-clutch transaxle, another powering the engine accessories -- draw power from a 132-pound battery pack mounted to the floor of the car's chassis. The V-12 alone produces 789 hp and revs to a screaming 9250 rpm. The electric motor adds 161 hp, and in total the HY-KERS (for HYbrid Kinetic Energy Recovery System) cranks out 951 hp and 664 lb-ft of torque.
Read more: First Look: Ferrari LaFerrari - Automobile Magazine
HY-KERS System | LaFerrari
Caterpillar has had an electric drive dozer for a few years now, trains and mining equipment for decades. Trains today can recover some of the energy on down hills and braking.
Caterpillar's D7E Electric Drive Redefines Dozer Productivity | Construction Equipment
http://www.constructionequipment.co...ar-d7e-dozer-tractor-hands-tractor-evaluation
With the Cat dozer everything is driven off electric motors, the motor only spins a generator. So the AC compressor, hydraulic pump, cooling fan and I think even the water pump for the motor are electric driven. It's been for sale since 2009 and so far from what I have read people like it.
Komatsu has also made a hybrid excavator. It can recover energy from its swing motor.
KOMATSU : Komatsu Introduces the World's First Hydraulic Excavator: Hybrid Evolution Plan for Construction Equipment
There are people working on better tech, but the day of a plug in tractor are a ways off still. Even then an electric will probably need some kind of liquid fuel to store energy.
/ 100 HP Plug In EV 4WD Tractor #5
I was just looking at Tesla's offerings yesterday. Nice car. With the 80kw battery you can go about 300 miles at normal operation (50-55mph). The car itself is aerodynamic and made of light-weight materials like aluminum and carbon fiber, which makes the performance possible. Given that 300 miles is the expected yield, run-time would be about 5 hours. This car costs $70,000.
If you take that technology and put it into a tractor, you get 5 hours of no-load running (probably 2 hours of "load"), and it would take half the day to charge it back up again. If you make the tractor out of light-weight materials you get a flimsy machine that can't handle heavy loads (tipping).
All this new technology comes at a cost - for $70,000 I could buy three to five "regular" cars, so why would most people buy "green" when it hits the wallet so hard?
Until battery technology improves and becomes cheaper, I wouldn't count on seeing a useful EV tractor in the fields.
no argument here, I agree with you. What is interesting about tractors is that in many cases, unlike their operators... more weight
is good. So the issue of battery weight, which is huge in packaging a car, is not a handicap on a tractor, or train? where the frame is
super strong. Never assumed the frame would be less capable. Drew
And yes, unless the bottom line cost per hour of operation is at least competitive, few could afford to run an EV sensibly.
But if one had a wind or solar farm...hmmm.
Likely it will take a while for this tech to "trickle down" from mining equipment to our ag tractors.
After Tier 4, where will they go from there?
I really do think the EPA wants our machinery to clean the air for them, not pollute it. So what comes out is cleaner than
what goes in, clean up that manure methane with your JD set on "clean" mode....
/ 100 HP Plug In EV 4WD Tractor #7
thanks.
Diesel is about 25% more efficient then gasoline in same sized tractors due to both the energy density of the fuel and the way it is burned in the engine. Hydrogen is not a substitute for petroleum based fuel as it takes more energy to separate the hydrogen out of water or any other source method then it contains and it is very bulky unless supercooled and compressed. A 100Hp tractor is about 70 KW and a battery that would last just one hour would weigh about four tons not counting the driveline and wheels etc. One that could put in a full days work equal to a full tank of diesel would be just ridiculous. No we will be using bio diesel from soy beans and sunflower oil and hog fat long before we get a practical electric drive field tractor.
Well, we're getting there...:thumbsup:
Min ten hours operation for a farm, maybe twelve.
So current tech is 40 tons of batteries. That might be a bit much on your front lawn...
but sure would be neat pulling out that stump.
I'm guessing five tons of batteries might be marketable on a medium range tractor, but
anything smaller might be overwhelmed. So they just have to go on a bit of a diet, from 40 to 5...
I think it will happen. And yes, we need to recycle our vegetable waste also.
Grow it, eat it, burn it, grow it again...
/ 100 HP Plug In EV 4WD Tractor #9
New Holland has a fuel cell tractor but I don't think it's for sale yet. They are still working on a way of getting hydrogen without more energy input than output.
Green Car Congress: New Holland showcases farm-ready hydrogen fuel cell NH2 tractor at Agritechnica; in service at La Bellotta Energy Independent Farm from summer 2012
Hydrogen Powered Tractor - New Holland
Methane might be a better fuel in the future, many large farms already have digesters. Storage seems to be one issue to get it to compress down to a smaller volume requires very high pressure.
Several years ago I read about a couple of different groups working on catalysts that would help with hydrogen. So far none have work that I know of outside the lab.
it takes deep pockets to develop these new capabilities, either corporate/industry investment
in their own competitiveness, or government funded. Since we are asking our current government to spend less,
this area may be vulnerable to the tap being turned off.
A small refit cost to run LNG or vegetable oil makes a lot more sense. Maybe we don't need to "get to the Moon" on this.
/ 100 HP Plug In EV 4WD Tractor #11
IMPO electric hybrids have a place like trains, mining and heavy highway equipment. With all of the good press, along with positive feed back on a few equipment forums. I'm a little surprised Cat only offers the D7 as an electric. Of course they are still just starting to sell electric trucks. I would think the 1st practical hybrid tractor would be a large high HP model. That seem to be from what I have read and my own experience would allow the space to fit all of the things to make something like this work. There are more problems with electric than just batteries. Many of these systems count on rare earth minerals which are hard to mine and in short supply. Electric motors are also large vs a mechanical or hyro transmission. Hopefully we find solutions to these problems down the road.
As far as the government, I don't mind if that can work in an honest manner. Unfortunately time and time again over the last 20-30 years and probably further back. When they pick winners and losers it's all about agenda and/or political payback. IMO that is why we have ethanol from corn which everything I have read is a net energy loser vs something different. There are other alcohols that work better, isobutanol is one, but the money goes to ethanol. Bush was big into hydrogen and switch grass based fuels, then Obama again because of his backing shifted funding to other areas. Probably the next admin will shift money someplace different, all based on who gave them money to get elected. With this type of system all that will happen is we increase our debt with zero forward progress.
/ 100 HP Plug In EV 4WD Tractor #13
I would imagine it would all depend on what you're doing.
I could imagine an electric lawn tractor used for a half hour or so, then plugged back in. Afterall, there are already electric lawn mowers.
However, a tractor is often used continuously, at a high HP usage, for hours. I suppose it depends on what kind of farming you are doing.
Anyway, it would all depend on the usage and charging facilities. For example, if one was spreading fertilizer, if one could do a rapid battery swap, one could fill up with fertilizer, do a few passes around the field, dump the battery, pick up a new battery, reload the fertilizer, and head off again.
What about a steam powered combine?
Thresh the wheat.
Burn the straw.
/ 100 HP Plug In EV 4WD Tractor #14
Thresh the wheat.
Burn the straw.
The Ag community has been there and done that. It is better then horse drawn McCormick reapers and hand threshing with flails but steam power is only about seven percent efficient vs. diesel power at about 34%. We need to look forward not backward if we don't want to see several billion people starve to death.
/ 100 HP Plug In EV 4WD Tractor #15
There is some market for straw now. But, until recently it was just plowed under. Your average combine produces a lot of straw, if it could be used for power at the source, it might at least save some diesel. But, it would probably be a pretty smoky prospect, unless it could be burnt very hot.
/ 100 HP Plug In EV 4WD Tractor #16
From the top-soils standpoint, considering both moisture retention and nutrient cycles I think it is better to leave the straw in the field.
/ 100 HP Plug In EV 4WD Tractor #17
Burning it, of course, leaves most of the nutrients behind, without the carbon.
Forget the over priced Ferrari, look at Cats electric drive dozers, and work from there.
http://www.cat.com/D7E
I enjoyed that site.
These motors are AC right? And the higher the voltage the better?
Better be real well insulated before you leave that tractor out in the field for the night in the rain...
not that you ever would. ;)
Ok. Where are my nuclear power cartridges like all the movies show?
But my understanding is that nuclear needs to create heat and usually steam, or superheated water, for
propulsion or power. All I want is AC, so maybe we have a ways to go before we get our little plug in power sources, good for
three+ years like our nuclear aircraft carriers. Much smaller of course, in the movies they are quite small...most convenient.
Probably provided by Sandisk. 2050. Gonna try to be around to find out, which is some serious wishful thinking at my age.
/ 100 HP Plug In EV 4WD Tractor #19
Im an EV and solar engineer....
What you say is very true. Tractors would be truly ideal for EV. Batterys can be sized for the say 50hp needed.. far less than a teslamotors.com? Also the battery pack would most likely be about 30kwatt.hours. Meaning you can charge it up for around $5 if you have solar panels. You would need about 10 solar panels to last you for ever... cost about $10k installed. You'll get some rebate or tax back too.. in some states. Lets see who's first to product?
/ 100 HP Plug In EV 4WD Tractor #20
As a reference point you have Tesla Motors new Model S.
Its electric. With 300 mile range. 0->60 in 4.4secs and 440hp. 85kwatthours of battery. Batts cost $40k.
Scale a tractor down from there.. tractors need WAY WAY less than 440hp or 300 miles range.. but pulls a load more.. My TC33 has.... well 33hp lol
probably used 6 hours a day at 550rpm full tilt? and 7 gals of gas? which is about 1/4 of a car's tank. So energy storage wize a tractor is about 1/4 that of a fast car? Thus batts would cost $10k?
Cheaper than a gas engine.. and tank and gear box.. etc.
