10 ft disk
/ 10 ft disk #1
Otter lake
John Deere 3020
Will my 3020 John Deere properly pull a 10 ft 3point disk
/ 10 ft disk #2
Depends on your ground and how fast you wish to pull it and how deep,
you are marginal, duals would help.
/ 10 ft disk
Trying to take some roughness out of hay field do I maybe need an 8 or 9 ft
/ 10 ft disk #4
I pull a 10’ disk with a Case 485 just fine. I’ve now got a JD 5425 (81 HP) that I’ll use to pull it with now.
/ 10 ft disk #5
The type of ground is not know.
Sandy loam, sticky clay, hardpan and rocks, gravely it will make a difference.
Discing up sod will be easy the first pass as far as traction.
Trying to get roughness out of a hay field will take several passes with a disc and the front to read setup and the angle of the disc will have a major effect on your results.
/ 10 ft disk
How much weight will a 3020 3 point lift
/ 10 ft disk #7
If I was looking for a disk for a 3020 and for what your are doing I'd be looking for a pull behind and not a 3 point.
/ 10 ft disk #8
A 10" will be too heavy for a 3020, unless you have some serious weights on the front. Even with weights, the hydraulics probably won't be strong enough to lift it.
If it were a 10' pull type disk with wheels, you would have no problem with the 3020.
/ 10 ft disk #9
Wait! What year 3020? And diesel or gas?
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
KMC 3PT W/ 3 X 3 TOOL BAR (A64278)
KMC 3PT W/ 3 X 3...
E-Z Trail 300-bushel Gravity Wagon (A66408)
E-Z Trail...
1995 Kiefer Built Gooseneck Trailer (A66285)
1995 Kiefer Built...
2007 Ford F-150 Pickup Truck (A64556)
2007 Ford F-150...
