1 Major RTV900 Problem
/ 1 Major RTV900 Problem #1
tractor127
Casa Grande, AZ
Ok I work at a dealer so im not making it up. The problem may just be Southwest related to the desert here in AZ.
But we have been having a lot of failer's with the spider bearing in the rear axles. The failures are mostly do to the bearing not being grease-able. If it could be greased we wouldn't have any problems with it. We have done 4 RTV's already all with this problem.
They seem to go out at any time. We had a couple around 1200 hours and the other 1 was only at 380 hours. But I think it may be caused more from the dryness out here and all the dust.
Has anyone else had this problem?
/ 1 Major RTV900 Problem #2
What are the symptoms? Can you describe what the failure looks or sounds like?
Thanks.
-Mike Z.
/ 1 Major RTV900 Problem #3
dealer replaced mine at 200 hr only sign was a occasional squeak comes and goes cost me 165.00 if it goes out again i will try to cross it over to a greasable one.
/ 1 Major RTV900 Problem #6
What is a spider bearing and where is it in the rear axle, I know what a spider gear is, never heard of a spider bearing, is it like a universal joint in a driveshaft only located in the axle?
/ 1 Major RTV900 Problem #7
So how about some answers to the questions people have ask of you?
tractor127
-Mike Z.
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
DYNAPAC CP142 ROLLER 9 WHEEL PNEUMATIC ROLLER (A67714)
DYNAPAC CP142...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2022 WESTERNSTAR DAYCAB 4700 CONCRETE MIXER TRUCK (A67714)
2022 WESTERNSTAR...
