1-2 Three Point Quick Hitch
/ 1-2 Three Point Quick Hitch #1
Oldtoad
Kennebec County, Maine
Kubota L4310, Bolens-Isiki
Have been looking for one of these.
Any manufacturers to avoid?
Supply issues abound, prices going through the roof, just saying.
Edit, after trying to buy a Speeco, just purchased a Titan. Will have to buy adapters, makes it easier.
/ 1-2 Three Point Quick Hitch #2
Not sure if you are wanting a Cat I or a Cat II. But make sure your implements are compatible.
/ 1-2 Three Point Quick Hitch #3
You'll probably want a cat 1, that's the most common size unless you have a big tractor and large farm implements. Cat 2 are wider than cat 1.
/ 1-2 Three Point Quick Hitch #4
I'm starting to look at these also. I DO NOT want to be messing with those "adapter" bushings. All my stuff is Cat 1.
/ 1-2 Three Point Quick Hitch #5
I believe Speeco makes a Quick Hitch for Cat 1 pins with no bushings. Every other QH out there requires bushings as the hooks are Cat3 pin sized.
That said I have a few impliments I can't put bushings on (King Kutter tiller) or haven't bothered. More slop, but they work fine.
Yes, I ordered a cat 1- 2 hitch for my Cat 1 tractor.
I do not want to buy adapters to make it is easier.
It is not cheaper.
Checked the dimensions, it will hook up to my stuff.
Going to buy some new pins and some adapters
/ 1-2 Three Point Quick Hitch #7
The reason for the bushings is they are supposed to be the wear part,
also it provides a much larger wear point then just the cat 1 pin in the quick hitch U.
One reason for the rotating and flexing balls in the three point is to reduce wear and slop.
/ 1-2 Three Point Quick Hitch #8
Yea but how much wear does the weekend warrior get?
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
2022 EZ-GO ELITE...
445 (A63290)
445 (A63290)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
