04 mccormick deering engine problems
/ 04 mccormick deering engine problems #1
nattynuts5886
Wattsburg Pa
1940s mccormick deering 0-4, 170 allis chalmer, 950 john deere, 7030 and 7040 allis chalmer 986 international
hello, i am rebuilding a mccormic deereing 04 and replaced bearings, pistons and every thing els and put engine in frame and tryed to use a pry bar to turn the fly wheel but it wouldnt budge do you have any ides what is wrong? thanks :ashamed::confused::ashamed:
/ 04 mccormick deering engine problems #2
What size rod & main bearings did you install ?? The pistons the same as the old one ??
/ 04 mccormick deering engine problems #3
Sounds correct. Were clearances measured before installation?
Yes every clearence was measured and was correct
/ 04 mccormick deering engine problems #5
Could the engine have to much compression that you cannot over come. Try turning it with the spark plugs out to releave compression.
/ 04 mccormick deering engine problems #6
Is it in neutral?
no spark plugs in and it still wont turn, is it possible for a connecting rod to get cockeyed?
it is just in the frame its not connected to the transmission just sitting in the frame no spark plugs in it either and it is still froze, it has new bearings and sleeves and pistons, could a connecting rod be in slightly wrong?:confused:
/ 04 mccormick deering engine problems #10
Could be a connecting rod installed backwards (180degrees out) or too tight of fit on the parts.
/ 04 mccormick deering engine problems #11
Rods and caps are numbered, as I'm sure you know, and numbers should face the camshaft side. Did you put a bit of oil on the bearings before installing..?? The rods caps and bolts are normally a pretty snug fit, so thinking it would be tough to be mis-aligned.
Is the cam and crankshaft timing mark(s) in proper alignment..?? Maybe try loosening the valve train assy., then see if the engine will turn over.
Was the crank turned, and machine shop supply the bearings, or bought in a kit..??
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
Frontier Forks (A64126)
Frontier Forks...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2022 EZ-GO ELITE...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
