Drill out to Cat 1?
/ Drill out to Cat 1? #1
Hunter8282
Central West Michigan, LP
2026 Kioti NS4710H Cab
Vevor ballast box.
Plan to fill with concerte. Came with Cat 0 pins and bushings. Would drilling the hole out to accept standard Cat 1 pins weaken that bracket too much?
Should I just stick with the pins it came with?
/ Drill out to Cat 1? #2
I'd drill it out, but I got a welder if it breaks ...
How much weight were you thinking of adding to it?
Are the pins spacing side to side right?
/ Drill out to Cat 1? #8
/ Drill out to Cat 1? #9
Or just put bushings over the existing Cat 0 pins.
Then if something breaks it is more likely to be the Cat 0 pin than the tab.
Cat 0 is 5/8" pin OD and Cat 1 is 7/8"
NAPA has hard nylon 1/2 x 7/8 for $2.00. Then drill ID to 5/8"
Home Depot sells real steel bushings with std 1/8" wall. A package of 5 for $12.
/ Drill out to Cat 1? #10
TSC also sells bushings.
/ Drill out to Cat 1? #11
Agri Supply has a Cat-0 to Cat-1 bushing, but if not somewhat local to you, the shipping will most likely be much more than the bushing. If you have a tractor house near you, you might want to check there. Cat 0-1 Lift Arm Reducer
/ Drill out to Cat 1? #12
Get a bridge reamer.....They come in all sizes....
Example:
That’s a good tool but kind of expensive for two holes.
A step drill bit would work and is was less $$ and any hardware store or Lowe’s/Home Depot will have them.
They grab less than a drill bit, but not as smooth as the reamer.
/ Drill out to Cat 1? #13
A farmer friend had a similar box some years ago for his TYM tractor- maybe the same one you have, as the name is familiar. After converting the pins to Cat 1, the whole assembly was too narrow to reliably use with a quick hitch and would fall off on one side occasionally.
I ended up re-doing (welding) the whole pin assy. using angle iron to make it wider and stronger. Sorry, I am unable to find any pics of the mods I made. But it now works well.
/ Drill out to Cat 1? #15
It comes with bushings. He’s looking to replace it with a solid pin that fits cat 1
/ Drill out to Cat 1? #16
BEST ADVICE.
/ Drill out to Cat 1? #18
/ Drill out to Cat 1? #19
If you have extra thread length on that cat 1pin, I'd drill the hole out to 7/8 and also drill a backing plate to stack in there to support the enlarged bracket hole. Or maybe find a large, thick washer or two...
/ Drill out to Cat 1? #20
You can get cat1 pins that thread into cat0 holes, i would avoid drilling while those are avaialble, so you can go back if you want.
Or use the Cat0 and add a bushing to fit Cat1. Don't have the size, but if you can't find one, start looking at different sizes of pipe. It doesn't have to be a press fit, just take up some space! Bronze or Oilkite (greased bronze) is available at places that sell bushings.
David from jax
