Drill out to Cat 1?
/ Drill out to Cat 1? #1
Hunter8282
Central West Michigan, LP
2026 Kioti NS4710H Cab
Vevor ballast box.
Plan to fill with concerte. Came with Cat 0 pins and bushings. Would drilling the hole out to accept standard Cat 1 pins weaken that bracket too much?
Should I just stick with the pins it came with?
/ Drill out to Cat 1? #2
I'd drill it out, but I got a welder if it breaks ...
How much weight were you thinking of adding to it?
Are the pins spacing side to side right?
/ Drill out to Cat 1? #7
Drilling is easy if you've got the right tools, so is putting new metal in place if you break it.
By tools means both physical tools and the ability to use them.
/ Drill out to Cat 1? #8
/ Drill out to Cat 1? #9
Or just put bushings over the existing Cat 0 pins.
Then if something breaks it is more likely to be the Cat 0 pin than the tab.
Cat 0 is 5/8" pin OD and Cat 1 is 7/8"
NAPA has hard nylon 1/2 x 7/8 for $2.00. Then drill ID to 5/8"
Home Depot sells real steel bushings with std 1/8" wall. A package of 5 for $12.
/ Drill out to Cat 1? #10
TSC also sells bushings.
