Grading Scraper
/ Grading Scraper #1
Duds13
Charlton, NY
Kioti CK2610, Kubota BX 2200
Looking to purchase a grading scraper for my Kioti 2610. Was planning on the Landpride GS1548 but then read that it should be a touch wider than rear tires which means stepping up to the GS1560. Any concerns with that model on my Kioti? Any others I should be looking at?
Thanks!
/ Grading Scraper #2
I'm not familiar with any of these model numbers but am guessing that we're talking about a 48" or a 60" grader.
So that means a pretty small tractor where the weight of the implement might be a factor.
How short of covering the tire track is the smaller 48" model?
Are your rear wheels adjustable for width?
/ Grading Scraper
Yeah the 1548 is 48", the 1560 is 60". The 48" would be roughly 6" short on each side. Not a huge deal I guess. Rear wheels aren't adjustable, or if they are it's not something I really want to mess with.
/ Grading Scraper #4
Covering the wheel tracks is definitely what you want. I'd compare the weight with the manufacturers 3 point rating.
If you have a little 48"-60" bush hog rotary mower for this tractor and it doesn't bother your steering (light front axle) you should be fine with a 60" grader.
The farther back an attachment "hangs", like a Bush hog the more it will effect the weight on the front and often important steering. 😉
/ Grading Scraper #5
I have a woods 84" land plane and while it is heavy and well built I'd have to say a brush hog weighs every bit as much. Cover your tracks - you wont regret it
/ Grading Scraper
I do have a 60" brush hog and while it is heavy as heck, it doesn't cause any steering issues. Thank you for the info, much appreciated!
/ Grading Scraper
Thank you for the info, definitely going with the 60"!
