Shawn T. W.
- Joined
- Jul 14, 2025
- Messages
- 2,043
- Location
- SW Missouri Ozarks
- Tractor
- Massey Ferguson GC 1725 MB - Kubota L5030 - John Deere Z960M
Well my mower engine is $3500![]()
Mines probably more than that!
Wow, didn't know that ... But since you brought it up ... when I think about the $17K price tag on my Z-turn ... I'm sure Kawasaki is getting a part of that for the 31 HP engine in it!
This is my "Lawn Train"! Cuts, de-thatches, sweeps ... All at once ...
My Hustler zero-turn (Kawasaki engine), and Wallenstein generator (Honda engine), both recommend 10w30 in most climates. 30HD is approved for warm climates (I'm in the DEEP south). My Hustler dealer recommends 30 weight. So that's what I use.Not another oil thread! I did a search and didn’t see it addressed. What do people do for small engine oil? It used to be straight 30 weight was called for but that seems outdated these days. I found some small engine 10w-30 Walmart branded oil and bought a couple of quarts. Is just regular synthetic 10w-30 ok, that seems like what I’ll probably start using.
Edit, the stuff I got at Walmart is straight 30 weight.
Non detergent is used in engines with no filter, detergent carries dirt with it to the filter.Not another oil thread! I did a search and didn’t see it addressed. What do people do for small engine oil? It used to be straight 30 weight was called for but that seems outdated these days. I found some small engine 10w-30 Walmart branded oil and bought a couple of quarts. Is just regular synthetic 10w-30 ok, that seems like what I’ll probably start using.
I can't think of any gasoline engine that I would use non detergent in. Maybe some engines in the 1970's and earlier were spec'd with ND when they were built. Detergents help keep piston rings free and deposits from forming through out the crankcase.Non detergent is used in engines with no filter, detergent carries dirt with it to the filter.
That’s an old saying from the earlier days of widespread adoption of synthetic oils. It’s kind of 1/2 true, and 1/2 false.Fully synthetic oils flow better at low temperatures than conventional oils. 5 points lower.
