Yard Rake...anyone use this?
/ Yard Rake...anyone use this? #1
NoCowboyhat
BX2680
After getting my tiller up and running, thanks to those who responded to my post about it (see link), I'm now dealing with another issue. My yard has about 3-4 inches of soft soil on top (it's awesome). However, there are a lot of small wood pieces from when I had a guy take out a couple dozen cedar trees with a skid steer. He ground them up but the pieces were larger than I thought they'd be so I had them removed. There are quite a few still remaining. So a diving catch in a football game could leave someone impaled on a 3-4 inch spike. I want to drag the yard to pick up as much of the wood pieces as possible. I was looking at this yard rake on Amazon. It should be good to drag through the soft soil and collect the wood chips/sticks. I saw another post on yard rakes from early 2025 and someone said they bought one from Amazon but hadn't used it. He never reported back after he put it together.
Anyone have experience with a rake like this? Again, it'll be dragged through the top few inches of soft soil to gather the wood hidden under the surface.
Tiller question:
/ Yard Rake...anyone use this? #2
Unless that dirt is like dust that rake is just going to act like a back blade.
A long time ago I removed every other tooth on my york rake and it did make it less like a back blade but will leave bigger stuff. However the amount it leaves is pretty small so I Judy pick the rest out by hand witch is what I suggest you do.
/ Yard Rake...anyone use this? #3
For doing cleanup after tree work we use the Groundskeeper II rake. They are light, very sturdy, and work great for getting the wood chunks out of the yard. Check around for best price.
The Groundskeeper II Rake
/ Yard Rake...anyone use this? #5
I think it worth try,if not successful maybe rake could be used for other projects.
A rake like that would work but the yard is far too big to do it manually. I started doing it by hand, putting the pieces into a wheelbarrow but progress was far too slow.
I think a pine straw rake would be better than a York rake.
This dethatcher might be even better.
How stiff are the tines on something like that?
/ Yard Rake...anyone use this? #8
I've used an ignite 7 footer to deal with post hurricane yard cleanup (not sure how similar that is to your amazon model). As others have said, it will move dirt along with the chunks you want moved. I found that setting it at an angle to make windrows that I could come back on gave me a better "trash/dirt" ratio in the end than straight pulls from the get go. Your tilled dirt may stay behind, it may get caught up. I wouldn't use over nice lawn since it will tear up grass, but if you have everything tilled already may not be a big deal. At worst, you collect the wood in one spot, get the wood up & gone, then use a box blade or the rake to level the dirt back out again.
/ Yard Rake...anyone use this? #9
Another option (if it is over lawn) would be to use mulching blades on your mower. Might need to block the chute if stuff nearby can be hit by wood, but a few mows, & it should all be small enough to not be a danger & will feed the lawn as it decomposes. I regularly do that with small branches/twigs. the yard rake was to handle 2 -15 foot branches up to 3-4 inches in diameter. Too small to burn as fire/smoker wood & too spread out to run my chipper to each location.
/ Yard Rake...anyone use this? #11
I think you can see replacement tines at TSC or any other farm store (if you have one near). You can see if they would work for you. most are a piece of round spring steel with a loop or three thrown in.
/ Yard Rake...anyone use this? #12
I did the same by removing every other tine but it really came to be useful when I put a chain in for the top link to allow it to flex. It no longer tears up the grass
/ Yard Rake...anyone use this? #13
What type of equipment would you be pulling this with and how large an area?
After clearing trees and stumps from 1.5 acres, used three step process. Like earlier response removed every other tine from 6’ landscape rake on 3pt hitch and let it dig/sift the topsoil for several passes while Tractor started compacting soil. then put all tines back in rack to catch smaller material and smooth out the grade.
Final step was to get on garden tractor mower and pull a 36” aluminum landscape rake for smaller bits - had to drive one handed and hang on to the rake handle but it worked good and left nice finish for seeding
/ Yard Rake...anyone use this? #14
See post #3 in this thread. As said in the post (sort of), you make a pass or two, then "dump" it. Still have to pick up or scoop up the rocks and other debris, but at least it's in a pile.
/ Yard Rake...anyone use this? #15
Not sure of your acreage, or what you are gonna pull this rake with ... I have a little dethatcher that I pull with my Z-turn ... It will snatch up twigs and stuff ... But needs some weight on it, or it will "hop"!
/ Yard Rake...anyone use this? #16
So - last week I got around to mowing all my lawn areas. Some areas had dead mowed grass more than six inches deep. No way I could gather it with a standard lawn rake. And I have no rake type attachment for my M6040 or ATV.
With my riding mower I blew the mowed grass into rows - as best I could.
Then I used my grapple to gather and relocate the grass rows. I'm surprised. This uber heavy duty grapple ( 820# ) dd a descent job. Only skurfed up the lawn in one small area.
But I sure could have used some form of rake attachment rather than the way I had to do it.
This is all because I got lazy. Didn't do the final fall mowing. Let the grass grow - and grow - all thru our snowless winter. Talk about being thick as the hair on a hound dog!!!
/ Yard Rake...anyone use this? #17
I've had very good luck with the Pine Needle Rake from Everything Attachments for a variety of things around my place. It is much less aggressive than a York Rake, but still sturdy enough to be effective.
I used it to remove moss that had overtaken a portion of my lawn. It took me several passes in different directions, but I was able to reseed it easily at this point. It also works well in the fall to remove branches form the lawn before I blow the leaves.
/ Yard Rake...anyone use this? #18
I had good luck with the York rake to gather up pine needles on afield that was being reseeded after tilling and disc-ing.
Being an ancient Servis brand it has fully adjustable trailing wheels which helps control digging in. Was even able to gather it up with the grapple to remove it once pulled into a pile. Been a while since we used it but recently it will be handy to sweep up pine cones and another area clean up of sand and 3/4 minus piles .
/ Yard Rake...anyone use this? #19
I think it’s worth trying. :)
/ Yard Rake...anyone use this? #20
I have both a dethatcher and York rake (with gauge wheels) from Heavy Hitch and they are both useful tools that are surprisingly complimentary in tasks.
The dethatcher/pine needle rake is good at gathering loose light material. I use it to... well, dethatch, rake pine needles, and clean up our horse paddock. On the yard, when I run it under the pine trees at the edge, I'm always surprised at how big a pile of pine needles it'll gather up. I'll gather them into a line and then run it in reverse to push the whole line into a pile and then into the compost, and it's surprisingly effective at this. It's not very aggressive on the ground itself so I can drag it on bare dirt to collect the loose hay without gouging the ground, and again, push it into big piles and the collect with the bucket. It's also good at breaking up the clumps of horse poop and spreading them out over a larger area to fertilize.
It's not good at pulling heavy material behind it. Once the pile gets heavy enough to overpower the spring tension of the tines and weight of the implement, it can't collect any more, and you'll have to either dump what you're dragging, or keep pulling and do another pass. And another. And another... So while it's really good at dry, light materials, it's terrible at wet, heavy, dense stuff.
The york rake is fairly the opposite - it's good at pulling heavy materials and other "heavy duty" tasks. It weighs a lot even without ballast, and is very aggressive on the ground. I couldn't see using this effectively without a hydraulic tilt capability and the gauge wheels, unless you were only needing it for trail clearing and maintenance, or on rough field work. A neat trick with the HH version is that I can attach it to the 2" receiver in my fork frame and use it on the front - the float and curl functions on the FEL are effectively the same as the 3-point hit with a hydraulic top link - though the weight of the FEL arms add a *lot* of weight, and you can't tilt.
It's hard to tell which is right without seeing your setup. I'm thinking the best comparison is to take some hand rakes to the materials and see what works best. If thin tines like a leaf rake are working well, the dethatcher would likewise do a good job. If you're using something heavier duty like a rock rake, then the York rake seems better suited.
If budget affords, you could try both, especially if you might have a use for them after (they are handy for lots of cleanup jobs!) - it's kinda fun to run the york rake on the FEL and the dethatcher on the rear at the same time. Or you could start with one and see how it does, the dethatcher is significantly cheaper. Renting might be a good option if you really only plan to use it for this one job, or finding used and reselling after if you get lucky.
