How much ballast do you need?
/ How much ballast do you need? #1
Shawn T. W.
SW Missouri Ozarks
Massey Ferguson GC 1725 MB - Kubota L5030 - John Deere Z960M
How much ballast does your tractor NEED?
What kind of ballast does your tractor NEED?
This is aimed at what I feel is what most of our members have for tractors, mostly under 80 HP … once you get into a couple hundred horses and 15,000 plus pounds, I'm sure it's different …
Ballast is to make your tractor more stable, and to hopefully allow you to never tip your tractor over, plus a balanced tractor will not cause it to wear out or break stuff prematurely.
There are basically three kinds of ballast …
Front Ballast.
Tire/Wheel Ballast.
Rear Ballast.
They all will almost always lower the center of gravity …
Front ballast is primarily used when lifting something heavy on the back, or pulling hard on something in the ground, like a bottom plow in a dirt field.
Here you can see that I added rocks to the bucket as front ballast to offset the heavy and long brush hog as I creep back into the creek bed, and want the front chained tires to pull me back up!
Tire/Wheel Ballast is primarily for TRACTION. (Sometimes confused with “rear ballast”)
Here I've added 275 Lbs of steel weight lifting plates to the BH frame to give me TRACTION ballast to assist the filled tires and steel wheel weights, while pulling a full load of dirt with the rear blade, since the weight of the blade is on the ground, it does help traction, since it's angled, it will try to push a light rear end sideways ... Not now!
Rear Ballast is primarily used when lifting something heavy on the front of the tractor to counter balance the load and keep the tractor stable.
Here is my rear ballast box, to counter balance the weight of the front tote, but also acts as a trailer hitch for the trailer with the rear tote!
There seems to be a lot of misunderstanding on rear ballast and why it's important, and what I'm addressing in this thread …
Unfortunately most tractor dealers do not even mention this topic, and lots of “Internet myths” floating around too, it seems many unknowingly embrace liquid filled tires, but refuse to add weight to the three point hitch … ?
Remember usually weight is a tractor's best friend! 🤠
Four years ago I was a new tractor owner/operator … I had run a tractor a few times in the past, way back, but didn't really know very much … I bought a tiny little Sub-Compact Utility Tractor (SCUT) Tractor Loader Backhoe (TLB) a Massey Ferguson GC 1725 MB, as I needed a backhoe (BH) for my new to me property, (couldn't get a contractor to even return my calls!) and back in 2022 there weren't many options due to supply chain issues, I was really looking for something much bigger … but ended up with this tiny little overgrown lawnmower! I got the three manuals for it, and read every word, I like to read and I thought I understood what I was supposed to do to operate it … and I got a lot of work done with it … unfortunately the manual is/was not very clear on HOW MUCH rear ballast was needed for operation!
This is all my manual says … huh??? How in the world am I to figure that out? (There is a member here that posted a picture of there manual which had a way with measuring things to figure it out, but I don't remember who it was, I think tractor and member are from Europe?)
For example when I took off the BH (651 Lbs) to put on the rototiller … I thought that was fine, as I had an attachment on the back … rototiller weighs 351 Lbs plus the 69 Lb quick hitch … how much do you think this load of rocks that I hand filled the bucket with that I “harvested” out of my “garden” weighs?
Sometimes I used my land plane (285 Lbs), but added a couple of hardwood timbers, a steel I-beam and a couple of cement blocks… was it enough? No way! (Now I know!)
At 347 hours I had to replace my front R4 tires, as the sidewalls were getting “cut” or maybe just failing? I have lots of rocky ground where I live, and I had filled the front tires with windshield washer fluid, so the leaks were obvious!
I decided to replace the 4 ply rated tires with 8 ply, as even with the tractor manual saying to inflate to 22 PSI, and the tire sidewall said the same, the poor little tires would “squat” under a full load at 22 PSI, sometimes it looked like the rim was almost on the ground! I figured if the hydraulics would lift it, it was “OK”! I ran the 8 ply’s at 35 PSI, sidewall said Max at 44 PSI!
By adding on the Bxpanded Piranha Tooth Bar, it expanded the volume capacity of the bucket, and I wasn't bashful about filling it until it spilled over the edges! That's a heavy load, but the tires aren't squatting anymore!
At just under the two year (bumper to bumper warranty) warranty was up, I had 385 hours on it … definitely “hard” hours … I took it in to the dealership for some recently acquired front axle leaks, both sides were leaking and so was the middle pivot! They fixed it all at no charge, but didn't ask me anything about it, or tell me to put more weight on the back …
But … I like to read … I was reading over at another tractor forum where @kennyd started a thread on ballast … I read it, and said “Ah HA! That's why I was leaking!” I broke my tractor from not operating it properly! Duh!!!
So I went about to build a multi-purpose ballast box that I could use with the loader when I didn't have the backhoe on, and didn't want the 8’+ long brush hog “in the way”, while the 5’ wide brush hog only weighed 518 Lbs, it had more effect than the BH, as it hung out so far from the rear axle, I actually needed ballast in the bucket up front when I mowed with it, as when the tail wheel would come off the ground, the steering was a bit too “light”!!! So there isn't a “magic number” for rear ballast, it depends on how much weight, how far from the rear axle, and how much you are lifting on the front!
Here's a few questions that may not have a real answer, but makes me wonder, did overloading the front axle cause my fluid to get “dirtier”? … the owners manual says to change the front axle fluid (hydraulic fluid) “every 2 years, or 500 hours” … I drained it at only 1 year and 244 hours, it looked like this!
I showed my dealer that picture, he said it looked “normal” !!!
Since my 8 ply tires don't squat like the old ones do, did that help wear out the seals, as there was no give in the tires? I've since reduced the front tires PSI to 20, and they still don't squat under a full load. (But I have more weight on the back now too!)
Here are a couple of videos with scales to show how ballast affects the tractor in different scenarios … scales don't have opinions!
Proves tire/wheel ballast doesn't relieve the front axle of ANY WEIGHT!
Shows how the typical advice of people that say “put as much on the back, as on the front” is still unbalanced … I would have liked to see how much adding another 10 bags on the back made the front lighter … and if he stated what the front axle was rated for.
I'm mostly trying to help new members who know next to nothing about tractors, and those that have been misled by the omission of information from dealers which have led to some myths … such as “if the rear tires don't leave the ground, it's enough”! Which is false.
I could have easily said to anybody that would listen … “Don't buy a Massey Ferguson, they are junk, I lost the front end out of it in less than two years, the seals were leaking and the oil was trashed!” When really it was ignorance on my part, and lack of usable communication in the manual! Nothing to do with the quality of the tractor!
It really doesn't matter what color paint, or what lettering is on the hood, ALL tractors with loaders need to be balanced!
/ How much ballast do you need? #2
I have a MF GC1715 and yes it is a sub compact..... When I am doing FEL work no matter what it is I run an approximate 600lb ballast (counter weight).... Its a steel box 2 x 2 x 1 ft (4 cubic feet) and filled with concrete, and concrete weighs in at approximately 150 pounds per cubic foot...
And wheel weights or fluids only help traction as rear axle is actually pivot point for counterbalance...
Another thing for stabilit is adding wheel spacer, I have added 3 inch spacers on my GC and it make a world of difference on the hilly terrain of my property....
NO picture in not photoshopped and the "runs like a dead Deere weighs in at about 520 pound according to its manual....
/ How much ballast do you need? #3
FWIW, I have my rear 8ply F1 tires pressure @ 12psi and they still don't have much of a sidewall bulge at the bottom when my 6' King Kutter is attached. Originally I had pressure @ 18, but had poor traction and lowered them to 12.
And how much does the steel box weigh before you put in the concrete?
I also run 3" spacers on the back ...
I run my rear R4 4 ply tires on this SCUT at 10 PSI ... no bulge ... Tires are filled 75% full with windshield washer fluid, and steel weights are 70 Lbs each.
But ... If I add some weight farther back, they do squat a bit ... That rock is roughly 16" X 36" ...
I run 8 PSI in my 8 ply R1's on the back here, front 6 ply R1's at 20 psi ... Once I fill that tote with water I'll probably need to add weight to the front.
I tried to look up the Kubota L2502 axle specs in that second video I posted back in the OP, I couldn't find the newer L2502 tractor that he is using, but the axles have to be very similar to the L2501 … note that Kubota numbers there loaders in lift capacity in Kilograms (Kg) … there are roughly 2.2 Lbs in 1 Kg … he has the LA 526 so it should be able to lift 1158 Lbs … making some educated/experienced “guess’s” on my part … let's say the concrete weighs 625 Lbs, the Pallets weighs 50 Lbs, and the forks weigh 300 Lbs … so he is picking up 975 Lbs about three quarters the lift capacity of the loader …
The Kubota L2501 brochure states …
The front axle is only rated for 2864 Lbs?
And here is a screenshot from that video with the end weights for the different senecios ... So with just the empty forks on, and the empty rear carryall the front axle is already overloaded! Can that be right???
Nevertheless ... Without anything other than the empty carryall on the back, the 975 load up front is going to ruin that front axle!!!
Here are a few pages from Kubota's loader manual … notice it says that BOTH tire/wheel weight AND rear ballast is REQUIRED for fel work …
Which is the exact same model the video guy had, he had a LA 526, this covers the LA 514, 724, and 854 ... Should still be close ...
They give a few examples of weight of rear attachments … notice how much the bh weighs!
Notice how all the pictures show using rear ballast with the loader ...
Which leads me to my next conclusion … if a bh is an option for a fel tractor, that is a good point to aim for … while it's possible to add weight to a bh, it's not always convenient … but the manufacturer has to realize that the TLB will be used with the fel, and has accounted for enough weight on the back for a proper and safe counte
r balance.
Does not really matter as it works as I want it to....
Yes, I think it does matter ... As others with a similar sized tractor, would want to know that information, as they are contemplating how much weight they should have for rear ballast ... Knowing what works for someone else I think is important. Your 675 - 700 Lbs seems to be a good weight.
In another thread a brand new owner of a GC1.25 had asked Google AI how much weight he should have, it's answer was "450 - 600" to which I responded that 600 Lbs should work OK. (Now I know I was a tad low, but also suggested to not fill it all the way, and be able to maybe add blocks to get it up to full weight ...)
Since I don't have a purchased, premade ballast box, or similar design, I only had to guess, as mine doesn't look like a normal ballast box, mine has recessed pins, and is wider than the lower arms ... Here you can see the pipe I used for the lower "pins" ... After the concrete was poured and set, I knocked out the 2 - 2X4's on each side (purple X's) that were bracing the form ...
Here you can see how the quick hitch is recessed into the ballast box, and how much wider it is than the lower arms, which keeps the weight close to the tractor, not like a typical ballast box one might buy.
/ How much ballast do you need? #8
I have read “Use enough ballast for the load you’re lifting”.
Yanmar states 1455 lbs recommended. Period.
It seems the manufacturers would ALL list GAWR’s. Then we don’t have to guess as much. Also, seems like the manufacturer would have the weight of an unladen tractor/loader/bucket on all four tires. That video from Tim is a prime example.
Yanmar states tire pressure sets axle weight max. My fronts are 3550 psi each and rears are 4410 psi each.
I have found numerous articles online and tend to read the one’s from agriculture establishments/universities. 2WD vs 4WD makes a difference.
My heaviest loads are usually a bucket full of material. A full/average bucket of dirt I estimate around 800-1000 lbs. My ballast is a box blade at 800 lbs.
Just last week, due to all the press on axle failures, I re-tested my setup.
With a full bucket and the box blade on the rear, tires properly aired, i can lift the load to max height with no bulging of tires noticed as well as stability in the tractor. Always have bucket low to ground when moving. Take your time.
/ How much ballast do you need? #9
Very early on I made a 55 gallon bucket filled with concrete as a ballast for my tractor. I estimate it's weight somewhere in the 1200 lb range. I think it is just bout perfect for my 30 hp tractor. I have been able to lift some heavy loads with ol' Bobby Branson!
/ How much ballast do you need? #10
My 2000 pound 2720 works well with a 600 pound ballast box filled with concrete to balance out my front 2 stage snowblower.
But when I have heavy work with the loader or pallet forks, 900 + pounds is great.
I try to match the job to the weight by hanging suitcase weights on/in the ballast box.
My 3039 doesn't need ballast. all it does is blow snow and mow with a RFM.
/ How much ballast do you need? #11
The good of liquid ballast is it's neutral axle weight, it's unsprung weight and doesn't effect the axle -capacity-. Technically it can be added to the tire weight capacity but the liquid in the tire absorbs the impacts radially so no one point takes the brunt of it.
If you have -axle weights- then that is added to the axle capacity.
I would love to have either but I would sink to my axle in the spring or late fall in some areas of the property.
Here is a good example of "not enough ballast"!
It's the opposite of what most people with a loader experience, as I was short on FRONT ballast! Each front tire has 75 Lbs of liquid in them, since this I added another 25 Lbs to each tire ...
You can see I also made a provision to be able to add my steel weight lifting plates to it, but wanted to see how it would work without ... I'm in The "Show - Me" State!
It has a quick hitch on the back which weighs 72.4 Lbs, then a set 3pt forks which weigh 487.4 Lbs, and a 134 Lb 275 gallon tote, full of water which is another 2200 Lbs ... So 2893.8 Lbs!
The tractor is rated for 3860 Lbs lift "at the pins" on the three point, and 2980 Lbs "24 behind" the pins" ... Notice the square at the purple arrow, that is the "pin" that hooks the quick hitch to the lower arm, and about a foot forward of where the water starts! So this is pretty much a "full load"!
So I went up to the barn and loaded up the weight plates ... Still not enough with 275 Lbs on the front!
While I was draining some water out ... I decided to "experiment" I climbed onto the front brush guard, and my 195 Lbs brought the front tires back to the ground, I got off and continued to drain until the front tires were on the ground ...
I then tilted the tank forward to bring more water, closer to the pins, and was just barely able to steer!
But ... I had to cross the creek, and as I was pulling up the other side, the tote was leveling out, water had shifted farther back, and I did a wheelie!
So I stopped, and drained out more water ... Until the front tires were back on the ground!
Here is a short 24 second video of it "coming back to earth"!
Not enough Ballast!
After draining it down, it finally was able to handle 175 gallons ... I added another 25 Lbs to each front tire since, and will be shopping for another 200 Lbs of steel weight lifting plates ... And probably try only 250 gallons of water ...
/ How much ballast do you need? #13
I haven't read this whole post, will come back to it!
My Kubota and John Deere are basically the same tractors in HP ratings, although the JD had a pump/injector change which pushed it up a few HP.
The Kubota had filled rear tires, and I have to have an implement on the rear of it to keep the rear wheels on the ground when using the FEL. The JD has never had anything hooked to the 3pt since I owned it, although I am considering hooking the landplane to it. The rear tires are foam filled on the JD which gives the tractor enough ballast that the FEL doesn't lift them off the ground, doesn't even come close.
The previous owner told me those rear tires weighed around 3500 pounds each. Might have been a guess, or he might have known. However, despite cuts, holes and other interesting things that would put a liquid filled tire down for a tire repair, these just keep going!
David from jax
/ How much ballast do you need? #14
I agree with Shawn T W that weight is needed to make a tractor do what we need it to do, and do it safely.
One thing I want to mention, especially after the video by ITC who stated adding wheel weight to rear axle would not remove weight from front axle. While that is technically correct, it is very misleading! Adding liquid to the rear tire doesn't remove any weight from the front axle like adding a rear 3pt ballast will. However, adding wheel weights or liquid ballast to the tires does not increase the weight that is supported by the axles or the "frame" of the tractor. The "frame" of a tractor is the engine, bell housing and transmission which are held together by bolts. Put xxx weight in the bucket and xxx on counterweight and you have added a lot of stress to those bolts and driveline parts. Adding wheel weights and liquid ballast to the tires does not add stress to those parts beyond the capacity of the FEL.
Adding spacers to the wheels is great for adding stability on uneven ground but combine added stress of 3pt weight and increased FEL capacity and you are starting to approach the limits of the fasteners that hold the wheels on and the parts together.
My point here, is be careful with this new improved capacity when you add weight, and try to add un-slung weight instead of weight that is carried by the frame of the tractor. I have seen way too many broken bellhousings, stripped bolt holes in engines and broken axles or sheared wheel lugs.
Don't get me wrong, I will push a FEL to its hydraulic limits, as the attachment shows with a 3970 pound lawnmower being transported by my JD2555. While it was really close to hydraulic limits, the rear end was not in the least bit "light", even with no attachment on the rear. It is all about un-slung ballast.
Getting off my bandwagon,
David from jax
/ How much ballast do you need? #15
Thanks for your contributions, everyone. I am just beginning to learn about some of these issues and I really appreciate the information and thoughts you have provided.
I am working with an new to me but well used Ford 4000 with an aftermarket Bush Hog (or Freeman?) FEL that was installed by the previous owner. It seems like a fairly common setup, but I have limited information to verify weights, lifting capacity, assuming it is all installed appropriately. Combined with my very limited experience, it could be dangerous or lead to damage.
I'm just trying to feel my way through this issue. I don't have any implements or rear ballast and I believe the tires are empty of ballast as well. I don't know the weight of the loader as configured. I don't know the hydraulic capacity of the loader. I don't know much, it seems. I have lifted a few small loads less than 1000 lb. I need to make a ballast box of some kind.
Based on what I am seeing in the owners manual
...the max weight and capacity of the tractor, implements, ballast, and load should not exceed 8250 lbs ? That doesn't seem like an awful lot, when I estimate:
Tractor 4500 lbs
FEL 1500 lbs?
Rear ballast? 600 lbs
Lifted Load?
Also, I'm not sure what each axle is rated for. The above manual says the rear axle can handle max 6200 lbs, but with the FEL, most will be on the front. Should I infer that the front axle is only rated for max 2000 lbs if the total is 8250? Heck, I don't even know if the front tires are up to it or what they will hold.
Perhaps I should have bought a tractor that was designed to operate as a FEL, not an old retrofit. But 5k was the most I could afford so here I am. The PO told me he used it for moving round bales, so I figured it would probably work for me.
Ain't she a beaut though?
/ How much ballast do you need? #16
Front Ballast.
Tire/Wheel Ballast.
Rear Ballast.
Wow, I know I was way off in my estimation of how much is enough. I have an old, old box blade that I think I'm going to convert to a multipurpose Tool rack/Ballast box when I get some time.
It is 60", but it probably weighs 600 without me doing anything to it because it is made really heavy. I'll put a bottom in it and put sand, gravel, or concrete in it to get it to #2k.
Thanks for this thread, very eye-opening!
/ How much ballast do you need? #17
Nice tractor!
First thing, we all had a steep learning curve with our first tractors! TAKE EVERYING SLOW, KEEP THE LOAD AS LOW TO THE GROUND AS POSSIBLE AND TRY TO STAY OFF OF INCLINES!
The tractor needs to have something on the rear to offset what you are picking up. With an implement (or if you spent the money to buy/build a weight box) on the rear, the weight being picked up will be spread out to both axles. If you don't have a rear counterweight, all the weight is being placed on the front axle. I know the transfer to the rear axle doesn't make sense, but it is a balancing act. Adding rear wheel weights or filling the rear tires with ballast (water in Florida, you need antifreeze up there) will help you keep the rear wheels on the ground (remember where your brakes are?) The reason for filling the rear tires over just adding a bigger counter weight is the tires are not weight that the rear axle has to suspend. That means it doesn't come into the formula when figuring out how much weight you can have on the rear axle because it isn't supported by the rear axle. (unslung weight)
Remember with 2 wheel drive, as you pick up more weight, the less weight is on the rear wheels and the less brakes you have! An implement on the rear (rear blades work nice) makes things go safer!
If you are going to be hauling rounds out of the field, consider a set of 3 point forks. That way you can pick up a bale on the rear, then grab a bale with the FEL and you have twice the work done as just using the FEL. The capacity of the rear 3 point should be a lot more than the FEL.
David from jax
ON EDIT...
I just saw where you were going to modify a boxblade into a rear 3 point counterweight. I wouldn't go thru all that, just put the boxblade on the rear and give it a try. If you need more weight, look around for some rear wheel weights (they are around!) or have some made. Another thing you can do is hang front end weights from the boxblade. (I just hate to see you make a boxblade into a counterweight) I don't use my boxblade since I built the landplance but still have it "just in case". You can hang all that weight on the rear, but you would help your rear axles and axle bearings if you would put some of the weight on the rims or in the tires.
David
/ How much ballast do you need? #18
My old ford Rear Anti freeze and the Old International BH. to help offset the FEL.. No PS.. The BH. is really heavy and will lift the front of my Yanmar Easily.
I have full relined Rear tires on it. Gempler, Decades ago! no Ballast. You can see the tires and the rear Displacement increase on it. Not the first complaint which 95% of the Hrs. on it is my Lawn mower. I reversed the rear wheel Disp. to get the longest width for any hills or inclines. Which in Ga. just isn't much of a problem. I've lost Traction on steep offset hills before. Kicked up the Drive wheel and talking about moving slow in the seat shutting it down! And the Notorious roll over! Mother was the kids bus driver! There when it happened! Truth is chained to a fence post though.
/ How much ballast do you need? #19
David from jax
I understand your point about un-slung weight. Since my tractor probably wasn't designed with a FEL in mind, maybe it's important to heed your warning about stressing the frame/bolts. Are there any other ways to do this besides wheel weights/ liquid in tires? Are you advocating for not using rear ballast at all, or just not excessive?
/ How much ballast do you need? #20
I am thinking just not excessive. The boxblade should be enough, to handle normal FEL weights. The unslung weights such as filled rear tires and wheel weights helps keep the rear end on the ground, but doesn't transfer any weight from the FEL to the rear axle. That takes a weight on the rear of the tractor to counter the FEL weight, otherwise the FEL weight all goes to the front axle. It is quite a balancing act that most people never realize and one I never thought about because my tractors are 70 to 80 hp. I can max out my hydraulics before I get light in the rear end on my JD and the Kubota has filled rear tires so it doesn't get light. I also seldom take the 8 ft bushhog off of the Kubota, so that is 2000 pounds (feels like more!!!) on the rear of the tractor.
If moving haybales out of the fields is your main objective, I wouldn't add any weight, just buy (or build...(ie, modify a Forklift carriage) to fit on the rear of your 3 pt. Use a bale on the 3 pt as ballast for the one that you are going to put on the FEL.
I have an abundance of 1" steel plate out back, and if I needed wheel weights that were hard to find or hard to pay for, I would just grab a torch and a drill and go to work.
David from jax
