Do I Dare??
/ Do I Dare?? #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
First day of spring and the long range weather looks to be mild here in the northeast. Do I dare take off the chains? I've got a lot of work to do this spring and the chains have to go.
The last time I took them off this early was in 1993. Two days later, we got hit with a blizzard and 32" of snow!
Should I risk it? If I'm wrong and we get another blizzard, I'll have hordes of TBN members on my back for sure! ;)
/ Do I Dare?? #2
Took my plow and chains off yesterday. I'm in Northeastern Connecticut . Long range forecast did not show any thing major. Last "big" snow I recall this late was on April,1 1999 or 1998. About 15"
/ Do I Dare?? #3
May 1 is when snow tires and chains come off is family lore in snow country… too often false spring followed by late snow…
/ Do I Dare?? #5
Would the chains help at all for possibly being in mud or will you be on hard ground, concrete, etc. where chains are detriment? That would assist me in the darned if ya and darned if ya don’t decision.
/ Do I Dare??
I'll be moving around 20 tons of fill and replacing it with gravel. I have to travel on a portion of paved surface, which the cleated chains would damage.
It is possible to plow without chains, but it's difficult on the slopes with the heavy wet snow we tend to get this time of year. Maybe I'll wait another week or so before removing them.
/ Do I Dare?? #8
🤔 Like darn if you darn if you don't,if the chains are p.i.t.a. to put on than gp with your gut feeling.
/ Do I Dare?? #9
Took the blower and snow push off about a week ago. I'm done with winter, and I'm really hoping its done with me.
I find with the plowing I do, I don't need to mess with chains and I'm thankful for that!
/ Do I Dare?? #11
I am curious what makes putting your chains on such a hassle?
What kind of chains do you have?
I run diamond net chains and for me, on this tractor, it is a less than ten minute effort to do all four; I lay the four chains out in straight lines in front of the wheels, and drive about halfway on. (This keeps me from rolling around on cold or wet surfaces.) Then I latch the inner chain at the tightest, lace up the outside chain and the chain keeper, and then latch, repeat three times. Drive back and forth to check chain tightness and I'm done. Usually, I need to tighten one or two wheels after ten or fifteen minutes of work. I do run at pretty low tire pressures on my R4s for better traction the soils here.
When I take the chains off, I try to store them so when I grab them out of my chain bins (they aren't light), the tire side is up.
Some years, I will put the chains on four or five times in the course of the year, depending on conditions, and because I try really hard never to drive on asphalt with them.
All the best,
Peter
/ Do I Dare?? #12
You live more south but myself up here I do not put anything away before easter weekend. After easter we are good to change the tires and snow blower.
/ Do I Dare?? #14
All the best,
Peter
There is a no-lifting method:
/ Do I Dare?? #15
All the best,
Peter
When I had chains on a machine, I would do similar, but I'd air down the tires pretty far before putting the chains on, then air them up after the chains were on. About 5 minutes a tire.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Frontier Forks (A64126)
Frontier Forks...
2019 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
2019 LAYMOR SM300 RIDE-ON SWEEPER (A65053)
2019 LAYMOR SM300...
Angle Broom (A64126)
