rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,896
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I was wondering the same thing....why is it even a decision to put chains on/off?I am curious what makes putting your chains on such a hassle?
What kind of chains do you have?
I run diamond net chains and for me, on this tractor, it is a less than ten minute effort to do all four; I lay the four chains out in straight lines in front of the wheels, and drive about halfway on. (This keeps me from rolling around on cold or wet surfaces.) Then I latch the inner chain at the tightest, lace up the outside chain and the chain keeper, and then latch, repeat three times. Drive back and forth to check chain tightness and I'm done. Usually, I need to tighten one or two wheels after ten or fifteen minutes of work. I do run at pretty low tire pressures on my R4s for better traction the soils here.
When I take the chains off, I try to store them so when I grab them out of my chain bins (they aren't light), the tire side is up.
Some years, I will put the chains on four or five times in the course of the year, depending on conditions, and because I try really hard never to drive on asphalt with them.
All the best,
Peter
It should eventually be easy to mount chains - although I do remember that until I get a set of chains fitted well, it is a hassle to change them.
I always use diamond pattern or connected ladders. Anything to keep the links up out of the treads, or at least out of some of the treads.
On our little - under 25 hp tractors - which always need to need chains the most, I would make chain sets out of old automotive or school bus chains. Making them to fit nicely to the tire so that no rubber tensioners were required. Part of getting rid of tensioners was going to over-center connectors on the chain, so that the connector had enough leverage and tension to make the chains fit nicely as they latch the chains into position. Then a twist of tie wire to insure the over center latch stays in place.
I guess what I am saying is that this is a good time to make the chains fit better so that the mounting problem goes away.
If I am in loose dirt or sandy dirt with turf tires I'll sometimes run chains year round.
rScotty
