Oil & Fuel Fuel filter placement help
/ Fuel filter placement help #1
Flemdog377
Yanmar 155D
Hey everyone, I just got my tractor home yesterday and noticed a few things that I'd like to fix and some that need to be fixed. I come asking this first question though.
Can anyone share a picture of the mounting location of the fuel filter assembly for a Yanmar 155d? The previous owner deleted it and I'd like to add it back.
/ Fuel filter placement help #2
From an online manual, perhaps this horrible picture may help:
/ Fuel filter placement help #3
The 155 FB-1 Fuel bowl same as this Dia. The YM1500 is pretty much the same tractor.
/ Fuel filter placement help #6
I do show the #FF-3262 2.717"tall 1.378 OD. My YM2000 same one long Ver. I use NAPA auto. #3262 also.
You say its pretty much the same, any thing that might not be interchangeable as I look for parts? Thanks for the help
The link from @careyo63 works for me.
A video;
IIRC: there's a long and a short version, but I don't know which fits on a 155D.
All the best,
Peter
This was extremely helpful, shows exactly the location i thought it belonged in.
/ Fuel filter placement help #10
Go to www.Tractordata.com and look at what they show. Great site to view tractor Info..
look under Yanmar YM1500 YM155 and it will give you the basics on the models.
/ Fuel filter placement help #11
A location that allows air to easily pass through the filter avoiding air lock b
/ Fuel filter placement help #12
In that era, Yanmars had two different height filter elements. With a different height fuel bowl for each. The filter assemblies with horizontal output were otherwise identical.
I suggest standardize on the element that was OEM spec for your tractor, even if you have to buy the matching bowl, just to keep future maintenance simple.
BTDT. Didn't realize my larger tractor uses the smaller element, after I had the old element in the trash can and the only replacement I had on hand, was too tall to fit.
/ Fuel filter placement help #13
On the YTOG we debated in good fun the shorter vs taller fuel filter and bowl. The conclusion was, if there is room, go taller.
To summarize the points for the taller:
- easier to check the bowl for contamination as it's taller. More junk keeps at the bottom while bouncing around on the land.
- shorter means, you change filters much more often at the same price of the taller filter.
- if you venture out into mowing a multi-acre pasture for the afternoon, better have a taller filter setup vs shorter, just in case it clogs up and you have to walk back miles!
- taller filter means more surface area available, thus it takes more time to completely clog.
- taller filter bowl is easier to grab onto with your hand whilst untwisting the locking ring. thus no fuel spilling over your hand like the shorter bowl.
- taller filter can be purchased in many places like auto parts stores, off-road ATV/UTV shops, and motorcycle shops. The shorter filter isn't as popular.
2025 Swict 72in. Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
