Harley rake repair
/ Harley rake repair #1
sov.worker
Ls 36 HST
Good day. A few days ago I bought a Harley Rake M6H power rake at a very good price. The problem is that the shaft bearing on the chain mechanism side was broken. The bearing housing is also missing. On the manufacturer's website, I found the device diagram and the part number I need - M6574. However, there is no information about the number and dimensions of the bearing itself. I found a poor quality photograph of the assembly I need, but I cannot make out the number. I really hope that someone can help me with my problem. I am interested in the bearing number or its equivalent, as well as its dimensions. I have no way to contact a dealer, as there are none in my country
/ Harley rake repair #2
Looks like a 1.75" ID bearing, but you would need to measure the OD, and the width of the bearing,
Good news — I can give you some solid information about the bearing you need for the Harley Rake M6H based on the parts diagram and genuine OEM listings: �
Endeavor Suite +1
What the OEM Part Number M6574 Actually Is
The part number M6574 is the complete bearing assembly (bearing plus housing) used on the chain-drive side of the Harley Power Rake. It’s listed specifically in the parts list for M-series rakes as:
M6574 – 1-3/4″ Cylindrical Bearing Assembly — includes the bearing and the housing. �
Endeavor Suite
This assembly corresponds to the shaft support on the chain (drive) side.
Bearing Details
While the exact OEM internal bearing code (e.g., 6205, NU206, etc.) isn’t published, we can extract the dimensional info from the OEM listings:
Bore (inner diameter): 1.75 inches (≈ 44.45 mm)
The assembly includes bearing insert and housing, so that bore size is what the bearing is sized for inside. �
Ford Distributing
From typical industrial bearings:
Dimension
Approx Value
Notes
Inner Diameter (ID)
1.75″ (≈ 44.45 mm)
Matches shaft size the bearing is intended for �
Ford Distributing
Outer Diameter (OD)
likely ~ 3.0″–3.5″ (≈ 75–90 mm)
Typical for bearings with ~1.75″ ID
Width
~0.75″–1.0″ (≈ 19–25 mm)
Typical industrial bearing width
To clarify — those OD and width values are estimated based on standard industrial cylindrical bearings with a 1.75″ bore. The exact numbers require either the OEM bearing reference from inside the assembly or measurement from the original part.
What You Can Do Next
Option A — Order the Complete OEM Assembly
You can order M6574 as a complete bearing housing assembly (bearing + housing). Since the original housing is missing, this is often the simplest solution because it fits directly without measurement or machining. �
Ford Distributing
Option B — Source an Equivalent Bearing Separately
If you want to only replace the bearing itself (not the entire housing), you usually need the exact bearing dimensions. Since the bore is 1.75″, a common bearing with that ID is an industrial cylindrical bearing such as:
NU/DN type series (e.g., NU222, NU206E, etc.)
Metric equivalents exist but keyed by OD and width
To pick the right one:
Measure the shaft diameter precisely where the bearing sits — it should be very close to 1.75″ if correct.
Measure the bearing housing inner diameter — this tells you the OD your replacement bearing needs.
Measure the bearing width — this ensures fit and proper spacing.
Then give those three numbers to a local industrial bearing supplier (NTN, NSK, SKF, etc.) — they can match an exact replacement.
Tips for Sourcing Locally
Many industrial bearing shops can match bearings if you take:
The bearing housing The shaft Any remaining bearing pieces or the dimensions
They can often cross-reference to standard bearings that are cheaper and easier to source than OEM bits.
Summary
Item
Info
Harley Part #
M6574 (bearing assembly for drive side) �
Endeavor Suite
Bearing ID (Inner Diameter)
1.75″ (≈ 44.45 mm) �
Ford Distributing
Exact Bearing Code
Not published (OEM keeps only assembly number)
Best Replacement Strategy
Order full M6574 assembly or match bearing measurements for a direct cross
If you want, I can help you estimate a likely bearing cross-reference (e.g., common bearing codes that are a direct physical fit) – just provide the outer diameter and width of your original bearing space (or any measurements you can take).
I've found a few possible options, but I'm not sure if they'll fit me.
IPTCI NA209-28L3
UC 208-24
ZUC 208-24
I'm confused because they have support screws. The videos I found on YouTube didn't have them. The image below shows their photos.
It's difficult for me to determine the exact size because I don't have the housing or the old bearing
  • 21-mm_-sharikovyy-s-kruglym-otverstiem-na-val-38_1-mm_-sfericheskoe-naruzhnoe-koltso.-Artikul-...jpg
/ Harley rake repair #4
UC 208-24
ZUC 208-24
These are 1-1/2", not 1-3/4". 208 is 1/2", 209 is 3/4".
The 209 series is a common spherical bearing and is used on discs, and many other applications. The Timken part number would be GW209PPB2 for a greasable triple lip seal bearing.
It appears that the M6574 is a spherical bearing with a round housing that is held in by a P015309 lock collar. The P015309 lock collar has some o-rings on it was well. This make me think it is more of a spacer that is also a sealing surface. So a bearing with a lock collar will most likely not work for you.
I do not see where the round housing is a off the shelf part. It might be a custom unit from Harley. I know that this did not help with finding the replacement housing. Keep us posted on what you end up doing.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
2022 John Deere 612R Sprayer (A63111)
2022 John Deere...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
