Realistic $ for a reliable tractor?
/ Realistic $ for a reliable tractor? #101
I doubt the rentals would have wheel spacers, but once the size is figured out, they can be added, same with fluid or steel wheel weights, which will increase side to side stability ...
If I could go back in time to 2022 when I bought my SCUT (which I love!) I would have been much better off with a larger framed 25 HP tractor like the Massey Ferguson 1825, or Kubota L2501, John Deere 3025 sized tractor, if they had been available, as they have much larger tires, and more loader lift capabilities, but still under the emissions system requirements ...
Once you get into the older ones, there are no emissions system on them, if that is important to you ...
I made 4" spacers for my compact. 4" was my dimension because it fit my 5' mower spacing for tires running in the cutter's path. I highly recommend spacers for any terrain or type of work. Even being on concrete with a good sized load in the bucket, making a tight turn really puts you at risk for a roll over.
Course I see a lot of 70-100 HP conventional tractors taller than they are wider going down the highway. Just wonder how they do in actual usage situations.
/ Realistic $ for a reliable tractor? #102
I kinda graduated from abusing/overworking my Kioti dk45s to getting another compact tracked loader. No longer do I abuse or overwork the tractor as I now have the proper tool for the job, whether that be construction or acreage work. Any attachments needed can be easily borrowed or rented. My buddy has skiddy too. He has a backhoe attachment and other attachments if I need them. Also helps that he is just 1-1/4 mile away just off my road. I have the tiller and trailers so we trade devices/attachments……and many an adult beverage.
Little update: Went and visited all the dealerships near me yesterday.
My local new holland dealer was kind enough to offer to bring out a workmaster 25s for me to demo on my property. We’re getting a lot of snow this next week which they understandably don’t want to trailer through, so gonna wait for that to pass before we actually get the tractor out here. But hopefully should happen in the next few weeks!
Even just driving them around the lots was super valuable and I feel like I learned a lot that no amount of online research would tell me.
/ Realistic $ for a reliable tractor? #104
Sounds like you have a reasonable dealer.
Did you mean the Workmaster 25s or the Workmaster 25? The "s" model features low weight, small turf tires, low ground clearance, and gearing optimized for mowing lawns. The regular Workmaster 25 is optimized more for the kind of small tractor work you mentioned in your original post. You might want to try them both.
rScotty
/ Realistic $ for a reliable tractor? #105
Yes, the "S" version is a SUB-Compact Utility Tractor (SCUT}, the plain one is a Compact Utility Tractor (CUT)
I Think you would be happier with a CUT sized tractor ..
It is indeed the 25s. Thanks for the notes on the differences! I did also look at the 25 while I was there. I imagine part of the willingness to demo the 25s for me is this particular tractor is a 2023. This was the only subcompact they had and it was literally dusty from not having moved when I looked at it, so I think they are motivated to go the extra mile to potentially sell it - as opposed to the shiny new compact+ units.
However, I actually really liked the maneuverability of the subcompacts and at the end of the day I’m just happy to try something out. Once it arrives it may very well feel super undersized or lacking the ground clearance I need, but then I figure I’ll know I need to step up in size and that’s still a good data point.
/ Realistic $ for a reliable tractor? #108
Yes, SCUT's are very handy!
I have one, and am AMAZED at what I've gotten done with it, but a bigger framed heavier tractor would do it faster, even with the same 25 HP ...
But it will be a good trial run for you to see what it's all about!
Here is just a tiny example of what I've done in the first 750 hours with my Little Baby Fergie TLB SCUT!
How do you find the ground clearance on your 1725? The MF dealer had a gc1723e i really liked, but the one big drawback to me was it looked to have a far lower clearance than everything else. I’m worried it would snag up tree roots and rocks in my trails.
/ Realistic $ for a reliable tractor? #110
I added a link to a thread I made about just taking little bites, after you quoted me ...
There is a transmission cooling fan under there, it's more than a foot off the ground, although front axle ground clearance is only about 6", and there are other things that low too ... but supposedly a few have managed to jamb a branch or root up and destroyed it ... I have a skid plate under it to protect it. Most SCUT's have the same setup ... You can see I got a few tiny nicks in my whitish fan blades ...
I don't have much woods here, but the pastures were quite overgrown ... With the tiny tires, I couldn't get up the other side of this creekbed, the long brush hog didn't help!
Just drive on through!
All finished!
There is a transmission cooling fan under there, it's about a foot off the ground, although front axle ground clearance is only about 6", and there are other things that low too ... but supposedly a few have managed to jamb a branch or root up and destroyed it ... I have a skid plate under it to protect it. Most SCUT's have the same setup ... You can see I got a few tiny nicks in my whitish fan blades ...
All finished!
Luckily I think all my tasks I can take small bites if need be! So my big concern is just getting the tractor to the spots I want it. I may very well need something with bigger tires though … that creek bed you couldn’t get up looks pretty tame compared to lots of my woods 😅
The again could just be the camera angle.
/ Realistic $ for a reliable tractor? #113
Yes, it is partly camera angle, but ...
The "problem" is mostly due to the nearly 8' long unforgiving brush hog on the back ... But the bigger tired CUT would probably be able to lift it higher, so it wouldn't ground out, that's why I've been suggesting a CUT, over a SCUT.
Bigger tires do have a bigger foot print, so better traction available if you have the weight ... They also provide a much better ride, these tractor don't have any real suspension, as you get bigger, they can have a suspension seat like my CUT does, but tire air pressure is mainly what is there!
/ Realistic $ for a reliable tractor? #114
I had been looking for a tractor for our hunting land for close to a year. I saw this one listed on Tractorhouse at a dealer 125 miles away and it was a very good price. I looked at their Google reviews which were universally good. I called the sales person, and got full and straightforward information. Even though the price was very good, I made a slightly lower offer, and got them to throw in free delivery (the sales person had a cabin 15 miles away).
I bought it sight unseen (yes, I know I could have driven the 125 miles, but it wasn't in the cards at the time). Not only was the tractor better than I thought, but they went over it before delivery to make sure every functioned as it should. I acted quickly, because over the course of my search, I learned that when you find a really good deal, it sells fast. YMMMV
looks like a B7800, I had one, great tractors!
/ Realistic $ for a reliable tractor? #115
I don't think the Workmaster 25 is a subcompact. I think it is a compact tractor. Sub-Compact tractors are very small framed, but very useful and handy for their size.
The Compact tractor frame size is a little larger and heaver and tires are usually bigger. The workmasters are Korean made machines, and Korean machines are making good tractors. The other Korean competitor to the Newholland Workmast is the TYM 25. It is one very powerful little machine for its size/cost. TYM is also Korean, but they are building great little tractors.
If I were you, I would not get in a big hurry. Sit on, operate, and read up on them for a while if you can. Binge on some "Tractor Mike" YouTube for learning about tractors and their operation.
You've gotten this response because you're asking a bunch of tractor enthusiasts for help with the one thing we all love to do: spend other people's money on tractors.
If you have a Yanmar dealer nearby, go sit on a SA325 or SA425, the same tractor with different tire sizes.
Massey Ferguson also makes a very nice, affordable tractor if you can find a good used compact size.
Yanmar, Massey, New Holland (older models) and Kubota are your best Japanese makers. John Deere (Yanmar) makes a good tractor but they are $$pendy
TYM, Kioti, and LS (New Holland) are the best Korean models in my opinion. Strictly my opinion, and you have already found that there are no two opinions alike.
So it could be that you are just shopping for the right tractor feel and dealer.
Yeah the 25 is a compact, the 25s they call a subcompact. Unfortunately I don’t have a TYM or LS dealer convenient for me so not considering those. I drove multiple kioti’s yesterday and found them uncomfortable for me, either my legs are too long or my arms are too short but just everything was awkward so I’ve eliminated them.
I did like the yanmars. However the sa425 wouldn’t start when we went to try it which wasn’t a great case for their reliability :/ while they called everything 425 and under subcompact they definitely all “felt” larger than their kubota equivalents.
I really liked the kubotas but they are definitely speedy for way less lift than competitors. Though everything about the dealer experience felt more premium than the others which I’m sure is part of what you are paying for.
MF felt really well built with way less rattle than the other tractors. But worried about ground clearance and I disliked how rough it started in the cold. By far the cheapest option.
New holland felt the most rattle-y and cheap. 2nd cheapest option though. I think the dealer near me specializes in larger ag tractors as they literally did not know any of the specs of the tractors I was looking at when I asked. They get major brownie points though for being the only dealership to offer a demo on my property.
Disclaimer these are my uninformed initial impressions from about an hour at each dealership, I’m sure they all make good tractors, ymmv.
Edit: Also should add that I put out my first impressions mostly so that y’all can tell me how I’m WRONG. Where are these tractors more (or less) than meets the eye. What should I be looking for when I inevitably check them all out again?
/ Realistic $ for a reliable tractor? #117
Went thru some of the same when we bought our Kubota. With 11 acres of trees and 900 feet of road, I find myself using it for something at least once a week.
Considered the ~20HP compacts but they felt like oversized law mowers, so went with 47hp and a 1600lb FEL, and glad we did. Spent more than what we planned, but found a 6 year old with less than 300 hours on it, and figured the lower hours were worth it. The stuff in the $10 to $15K range was super high on hours, and being an hour from the dealer, breakdowns would be really expensive hauls...
/ Realistic $ for a reliable tractor? #118
Well, that's a novel way to judge your first impressions....but I think I see what you are asking. So here goes, hope something is helpful.
An uncomfortable cockpit? Or is it just not easy to jump on & off? Well, for me either one would take that brand off the list. The same would apply to any other brand. Seating and layout does vary. Some cockpit layouts will fit your body and others not. How it feels initially is important. Same with shoes, hats, or gloves - they may work equally well, but the basic fit won't change with time.
Yes, unfortunately for a tractor novice it does make sense to eliminate dealers that are not convenient to you. You HAVE to reduce the choices somehow, and for convenience not to make sense would take something special. Since there is a lot of competition in the medium price range, I doubt you are missing a unique deal.
It would be wrong to judge Yanmar on the basis of one that didn't start. Yanmars really are consistently high quality for the dollar. And very innovative. One that doesn't start says a lot about that dealer's sales people, but nothing important about the brand. Lots of brands use Yanmar engines. Give it another look.
Kubotas are spendy. Their dealerships look and are professional. You pay for that, and in return get a premium product that maintains value. Check the fit carefully, not everyone likes Kubota's right foot pedal.
A lot of owners seem to buy Kubotas the second time around, though for a novice it may not make sense to invest premium dollars right now - at least not until you know more about what you want in a tractor.
As for FEL lift, much of that is an advertising game. Actual lift is roughly the same in any similar size tractor, and all will lift more than a novice should be carrying. Tractors of any size are limited by stability on even a slight slope, not by their ability to lift a load on flat ground .
If you really want to compare FEL loaders, check how well you can see the bucket angle when seated. and try the FEL control levers to see if they allow you to easily and accurately move the bucket ever so slightly... A lot of FEL quality and cost goes into giving the operator the ability to make small precise bucket movements.
Masseys have been around for a long time. I don't know them well - they are not common where I live. But in the compact and utility size they have always had a reputation for good solid construction which you saw.
Rough starting?? In cold weather ALL diesels tend to start rough. Most of us plug in the block heaterfor a few hours to help with starting them on any winter day. If you really want to compare starting, feel the engine block to see if it is warm. Even a little heat from running hours before will make a huge difference in how a diesel starts.
Lots of good conversation about Massys here on TBN. It's a contender.
I wouldn't let the friendly New Holland dealer sway you too much - particularly on a 2023 Subcompact model that the big Ag dealer is trying to move. I'd want to know a lot more about why it is still there. This is a tool you are buying. Economizing on a tool may not be the same as buying what will work for you. If you want to get a sense of how owners feel about their tractors, do a search in that brand's forum here on TBN.
Something you have not mentioned are transmission types. A transmission is the heart of a tractor. The various types \all work well. So get one that you enjoy using. It will probably be a HST. If all else is equal, more gears and more gear ranges are better than less.
Enjoy the search,
rScotty
/ Realistic $ for a reliable tractor? #119
All of the 60 HP and smaller Massey Ferguson's for the USA market are made by Iseki, I'm not sure if they all are made in Indonesia like mine, but I consider it a great tractor, although much smaller than I originally wanted, I'm keeping it now!
Both Massey Ferguson and Iseki (a Japanese brand tractor) are owned by AGCO they are sold in the USA as Massey Ferguson.
What model of Massey Ferguson did you look at? The Massey Ferguson 1E.25 is a MUCH Larger tractor than my GC, and a Compact Utility Tractor (CUT) and should have plenty of ground clearance, comparable to all other CUT's
Back about a month ago we had 1°F ... Even with a 1.5 amp BatteryMinder which has temperature compensation plugged in all night, and a extra long glow session, it wouldn't start, I put a propane torch on the oil pan and hooked up a 10 amp battery charger, in 10 minutes it was running! I just installed a block heater, going to test it this morning in a little bit ... https://www.tractorbynet.com/forums/threads/diesels-and-cold-weather.643934/ when I was at my dealer getting the block heater, the dealer told me both he and his mechanic which both have GC's like mine had trouble starting too ...
I too wouldn't discount the Yanmar tractors, unfortunately some salesmen don't know anything but what the literature says, and some don't even know that ... How cold was it out? Could also have been sitting for quite awhile (months?!) since it was last run, so battery wasn't cranking it well ...
The New Holland is made by LS ... I too would question why it has been on the lot for three years? Is it now a demo? A return? Just a model nobody wants?
Another thing you get with Kubota is a fairly well stocked parts department, and access to a warehouse that can get replacement parts quickly, I'd consider it a "Premium" brand, but you get what you pay for in parts availability and knowledgeable service, in a professional setting ... For a new tractor owner the "treadle pedal" (forward and reverse pedals) I'd think would just be natural to get use to, lots of people run them ...
My Massey Ferguson was the first diesel fired hydraulic powered tractor I owned, I got VERY use to the twin side by side pedal, and now prefer that style, my much more recently and little used Kubota has the treadle pedal, I can use it, but it feels awkward to me to not keep my heel on the floor, so ... I just lift the forward pedal by sticking my toe under it and lift, keeping my heel on the floor ... I make it work!
You can see the pedals with the arrows on them, the two side by side pedals above are the brakes ...
Side view ...
/ Realistic $ for a reliable tractor? #120
Seems like you are doing your homework. It's ironic that the Yanmar didn't start, my Yanmar tractors start easier than any tractor I've ever owned in any temp. Also, arguably the most reliable tractor you can buy. That dealer may not be a good one to have a tractor that won't start.
I would buy a compact size Massey or Yanmar over any you mentioned above.
However if you suspect you may need to sell or upgrade to larger later, the Kubota will be easier one to sell later.
The workmaster is made by LS and I would buy New Holland over LS Even though they're the same tractor because there are more New Holland dealers, generally speaking. Although the amount of dealers in any state varies significantly by tractor make
I don't think you would be going wrong with that New Holland
Jack Daniels Metal Sign (A65583)
Jack Daniels Metal...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
2025 Vicsec 30in. Bucket Mini Excavator Attachment (A64553)
2025 Vicsec 30in...
Cattle Feeder (A65640)
40' One-Trip Shipping Container (A66285)
40' One-Trip...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
