Wide pallet forks
/ Wide pallet forks #1
SRSeedBurners
Pottsboro, Texas
Kubota M8540
Started a thread a few weeks back looking for pallet fork recommendations and was directed to the Express Steel forks which I nearly pulled the trigger on. A set of Land Pride PFL5648 popped up in my FB marketplace that stopped me. I was about to purchase those and then looked up the specs and found they are too narrow. The Express Steel forks are too narrow as well. I have a safety cage that I use on the forks that require the outside edge of the blades to be 51.5 inches. THe borrowed pallet forks I'm using, which are john deere with an adapter for my kubota, has a total width of 55.5 inches. All the forks I'm looking at online are width in the 40s. Now I'm on the hunt for wider than normal pallet forks. The land pride PFL5660 are wide enough but come with 60" forks which are too long. Any suggestions? Pics of the safety cage, cage fork channel width and the tape holder for tax
/ Wide pallet forks #2
Normally the forks are roughly the width of your loader arms. I’ve never seen any that go wider but that doesn’t mean they don’t.
/ Wide pallet forks
Here's the right side loader arm with the current JD fork mounted. You can see the forks extend out beyond my arms.
/ Wide pallet forks #5
I have the Titan 60" wide pallet forks. I wish I had gone with the 72" wide. The forks I had on hand did not fit the frame well and I had to grind the top rail to be round rather than square. I do not use them much as I have 72" long forks on them, however they are nice to have when I need them.
The following make wide pallet fork frames.
Bradco
Blue Diamond
CL Fab
arrow
Loflin
proworks
Virnig
Messer
There are probably more. But this is what I was looking at.
2012 Volkswagen Passat Passenger Car, VIN # 1VWBH7A33CC033108 (A61165)
2012 Volkswagen...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
429888 (A61165)
429888 (A61165)
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
