Bobcat with Kubota engine
/ Bobcat with Kubota engine #1
ironman1952
2023 Kioti RX7320pccb
So just purchased a 2026 Bobcat E35R2 and it has a 3 cylinder Kubota engine. I am trying to find some in depth info on the engine.
Does this engine not have a fuel rail sensor?
Is it a turbo?
Is there a source besides the Bobcat service manual?
Something specific to just the engine?
Help !! :cool:
/ Bobcat with Kubota engine #2
There should be an engine model number on the valve cover. Google that for more info.
/ Bobcat with Kubota engine #3
Your dealer should have, and could still, answer all of these questions for you.
/ Bobcat with Kubota engine #4
Are you sure its a Kubota engine? My understanding was that Bobcat switched over to Doosan engines around 2014-15.
Sent from my SM-S921U using TractorByNet mobile app
/ Bobcat with Kubota engine #6
LOL, I just traded for an old Wide Area Mower that a friend did some work to get. He was told it had a rebuilt Perkins diesel in it. I was over there, saw it had been sitting a while and tried to buy it. Finally traded one of my projects for his project. What clinched the deal, was when I opened the hood, I told my friend that the previous owner had lied to him. I said "NO WAY THIS HAS A REBUILT PERKINS DIESEL IN IT! He asked how I knew that, and I pointed out the big letters across the valve cover that said KUBOTA!
A lot of people have equipment that they don't know what engine is in them!
David from jax
It is a Kubota 3 cyl. I have the full service manual but wanting more specs and a better service manual for that specific engine from Kubota
/ Bobcat with Kubota engine #8
I just looked it up, and they are running the Kubota D1803-M-DI.
The older E35 used the D1803, I'm pretty sure the newer models use the Doosan DMo1(D18) which is a 1.8L turbo.
When the switchover occurred I'm not sure, but I know they were switching to Doosan in a lot of their lineup in the 2014-15 timeframe.
Bobcat also list it as a "Bobcat" engine on their website rather than Kubota.
/ Bobcat with Kubota engine #9
Is it a turbo?
Help !! :cool:
does this help?
operator and WSM manuals a plenty for free all over the internet and from Kubota.
D1803 is a 1.826-liter, 3-cylinder vertical water-cooled 4-cycle diesel engine, producing 26-37 kW (35-50 hp) at 2700-2800 RPM. Common in industrial applications, it features indirect (E-TVCS) or direct injection, with turbocharged (CR-T) or naturally aspirated versions, weighing 151-196 kg.
Core Technical Data
Engine Type: 3-cylinder, 4-stroke, liquid-cooled, vertical diesel.
Displacement: 1.826 Liters (111.4 cu. in.111.4 cu. in.).
Bore & Stroke: 87.0 mm×102.4 mm87.0 mm cross 102.4 mm (3.43 in×4.031 in3.43 in cross 4.031 in).
Rotation: Counterclockwise (viewed from flywheel).
Weight: ~185–196 kg (407−432 lbs407 minus 432 lbs).
Combustion System: Direct Injection (DI) or E-TVCS.
Models
D1803-M (Naturally Aspirated): Approx. 26.3 kW26.3 kW (35.3 HP35.3 HP) at 2800 RPM2800 RPM
D1803-CR-E5 (Common Rail): 28 kW28 kW(38.07 HP38.07 HP) at 2700 RPM2700 RPM;115.8 m115.8 Nm torque.
D1803-CR-TE5B (Turbocharged): 37 kW37 kW(50 HP50 HP) at 2700 RPM2700 RPM;150.5 Nm150.5 nm torque.
Dimensions
Length: 551−746 mm551 minus 746 mm (21.7−29.4 in21.7 minus 29.4 in).
Width: 536−554 mm536 minus 554 mm(21.1−21.8 in21.1 minus 21.8 in).
Height: 711−745 mm711 minus 745 mm (28.0−29.3 in28.0 minus 29.3 in).
Key Features
Emissions: Compliant with EPA/CARB Tier 4, EU Stage V, and Stage IIIA.
Technology: Some models feature Common Rail System (CRS), Diesel Oxidation Catalyst (DOC), and Diesel Particulate Filter (DPF).
Maintenance: MoS2 coated pistons.
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2005 Terex TX55-19 4x4 5,000lb Rough Terrain Telehandler (A64553)
2005 Terex TX55-19...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
INTERNATIONAL 700 SERIES 6 BOTTOM PLOW (A64278)
INTERNATIONAL 700...
PALLET OF AXLE TAKE OFF'S & CYL (A64278)
PALLET OF AXLE...
