Bobcat with Kubota engine
/ Bobcat with Kubota engine #1
ironman1952
2023 Kioti RX7320pccb
So just purchased a 2026 Bobcat E35R2 and it has a 3 cylinder Kubota engine. I am trying to find some in depth info on the engine.
Does this engine not have a fuel rail sensor?
Is it a turbo?
Is there a source besides the Bobcat service manual?
Something specific to just the engine?
Help !! :cool:
/ Bobcat with Kubota engine #2
There should be an engine model number on the valve cover. Google that for more info.
/ Bobcat with Kubota engine #3
Your dealer should have, and could still, answer all of these questions for you.
/ Bobcat with Kubota engine #4
Are you sure its a Kubota engine? My understanding was that Bobcat switched over to Doosan engines around 2014-15.
Sent from my SM-S921U using TractorByNet mobile app
/ Bobcat with Kubota engine #6
LOL, I just traded for an old Wide Area Mower that a friend did some work to get. He was told it had a rebuilt Perkins diesel in it. I was over there, saw it had been sitting a while and tried to buy it. Finally traded one of my projects for his project. What clinched the deal, was when I opened the hood, I told my friend that the previous owner had lied to him. I said "NO WAY THIS HAS A REBUILT PERKINS DIESEL IN IT! He asked how I knew that, and I pointed out the big letters across the valve cover that said KUBOTA!
A lot of people have equipment that they don't know what engine is in them!
David from jax
It is a Kubota 3 cyl. I have the full service manual but wanting more specs and a better service manual for that specific engine from Kubota
/ Bobcat with Kubota engine #8
I just looked it up, and they are running the Kubota D1803-M-DI.
The older E35 used the D1803, I'm pretty sure the newer models use the Doosan DMo1(D18) which is a 1.8L turbo.
When the switchover occurred I'm not sure, but I know they were switching to Doosan in a lot of their lineup in the 2014-15 timeframe.
Bobcat also list it as a "Bobcat" engine on their website rather than Kubota.
/ Bobcat with Kubota engine #9
Is it a turbo?
Help !! :cool:
does this help?
operator and WSM manuals a plenty for free all over the internet and from Kubota.
D1803 is a 1.826-liter, 3-cylinder vertical water-cooled 4-cycle diesel engine, producing 26-37 kW (35-50 hp) at 2700-2800 RPM. Common in industrial applications, it features indirect (E-TVCS) or direct injection, with turbocharged (CR-T) or naturally aspirated versions, weighing 151-196 kg.
Core Technical Data
Engine Type: 3-cylinder, 4-stroke, liquid-cooled, vertical diesel.
Displacement: 1.826 Liters (111.4 cu. in.111.4 cu. in.).
Bore & Stroke: 87.0 mm×102.4 mm87.0 mm cross 102.4 mm (3.43 in×4.031 in3.43 in cross 4.031 in).
Rotation: Counterclockwise (viewed from flywheel).
Weight: ~185–196 kg (407−432 lbs407 minus 432 lbs).
Combustion System: Direct Injection (DI) or E-TVCS.
Models
D1803-M (Naturally Aspirated): Approx. 26.3 kW26.3 kW (35.3 HP35.3 HP) at 2800 RPM2800 RPM
D1803-CR-E5 (Common Rail): 28 kW28 kW(38.07 HP38.07 HP) at 2700 RPM2700 RPM;115.8 m115.8 Nm torque.
D1803-CR-TE5B (Turbocharged): 37 kW37 kW(50 HP50 HP) at 2700 RPM2700 RPM;150.5 Nm150.5 nm torque.
Dimensions
Length: 551−746 mm551 minus 746 mm (21.7−29.4 in21.7 minus 29.4 in).
Width: 536−554 mm536 minus 554 mm(21.1−21.8 in21.1 minus 21.8 in).
Height: 711−745 mm711 minus 745 mm (28.0−29.3 in28.0 minus 29.3 in).
Key Features
Emissions: Compliant with EPA/CARB Tier 4, EU Stage V, and Stage IIIA.
Technology: Some models feature Common Rail System (CRS), Diesel Oxidation Catalyst (DOC), and Diesel Particulate Filter (DPF).
Maintenance: MoS2 coated pistons.
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
3Pt Poly Red Ball Tank (A66408)
3Pt Poly Red Ball...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
2025 SDLANCH SDL2030GT Heavy-Duty Greenhouse Tent (A64194)
2025 SDLANCH...
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
